Steering Returnability - Left turns 99EK
Old Jul 26, 2016
c3rberu5's Avatar
c3rberu5 is an unknown quantity at this point
Hey All,
Having some issues with the steering returnability in a 99 EK.
- Power steering
- Right turns wheel returns normally after turns
- Turning left, wheel does not return at about from 0-40 deg, further turns it will start returning, but hesitates at the 40deg mark.
- Recently swapped out inner outer tie rods / rack ends and had it aligned
Any ideas? had a possible lower ball joint issue come up, bad rack a possible bad alignment but if you have any other ideas i can look into before i do that it would be appreciated.
Thanks in advance!
Old Jul 26, 2016
Re: Steering Returnability - Left turns 99EK
lift car, poke everything around. inspect for cracked bushings. could also be power steering.
Old Jul 27, 2016
Wankenstein's Avatar
Seems like the most likely suspect(s): http://www.agcoauto.com/content/news/p2_articleid/116
Old Jul 27, 2016
c3rberu5's Avatar
Thanks guys, will check it out.
cukaracha
Dec 13, 2015 01:52 PM
BIG AL2289
Dec 6, 2015 05:59 PM
Trainingdragon
Suspension DIY
Oct 23, 2015 07:12 PM
hcivic95
Oct 22, 2015 06:08 PM
aZnVoYCe
Jan 22, 2002 08:59 PM
