Window won't roll down completely...
Old Dec 23, 2015
wootah88's Avatar
wootah88 is an unknown quantity at this point
My window recently decided it would only roll down about 5 inches and then stop. Then when I go to roll it back up it won't go...I have to wait about 5-10 minutes before it will actually roll back up. Any ideas of what could be wrong? I'd rather not buy a completely new motor and install it, only to find out that wasn't really the problem...
Old Dec 23, 2015
Re: Window won't roll down completely...
Test, don't guess.
Use a test light to see if power AND ground reach the motor
Use jumper wires to a battery to operate the motor
Old Dec 24, 2015
wootah88's Avatar
I don't have a test light unfortunately...Any other way that I can test it out? I'm guessing no but figured I'd ask...
Old Dec 24, 2015
12v test light $3 at Autozone.
Make one from a #194 license bulb and some wire, paper clips, and black tape.
Hell, unbend the wires on the #194 bulb and stick it in the connector for the window motor
Old Dec 25, 2015
CraigW's Avatar
Those test lights are great & cheap. They provide a load a dmm cannot, and have the needle tip you can pierce insulation to test without damage or need to expose wire.
BigLeg
Exterior
Dec 8, 2015 05:36 AM
Shrader335
Dec 4, 2015 11:23 PM
jmdinn
Dec 3, 2015 01:53 AM
spatel133
Dec 2, 2015 12:05 AM
mercerguy323
Nov 26, 2015 07:24 PM
