97 LX with possible CPS issue
Old Apr 5, 2015
arcamm's Avatar
arcamm is an unknown quantity at this point
I'm looking at a 97 Civic LX with 141000 miles for my son to drive. Car is in good shape, but after sitting for about 6 months, it's started to throw a crankshaft position sensor error. I don't remember the exact number. The car starts just fine but after it warms up, the idle begins to rise and fall. I've driven it a bit and it seems to run fine, but I never drove it over 45 mph. The seller said he was told the wiring on the sensor could cause this issue. One dealer I talked to said that these sensors usually just die and it could be that the timing has skipped and that would most likely bend a valve and destroy the engine. Maybe, but it runs better than any other engine I've ever run with a bent valve.
Anybody have any suggestions on what the issue might be?
Thanks,
Old Apr 5, 2015
Re: 97 LX with possible CPS issue
Would help to know the actual code.
The sensor on the front of the engine by the crank timing gear is a CKF sensor, whereas your CKP sensor is inside the distributor.
Old Apr 5, 2015
arcamm's Avatar
I don't know the exact code. I'm going by what the seller told me. I'll see if he knows the code.
Old Apr 5, 2015
Go to local parts store (open on Sunday, DangerZone?) and have them do the free code read. Write down the code number(s) and report back?
PiCASSO
Apr 23, 2002 12:38 AM
CIVICTypeRookie
Apr 12, 2002 09:09 PM
droidekaus
Mar 18, 2002 02:06 PM
PiCASSO
Mar 10, 2002 01:34 PM
RiCeGrL
Feb 21, 2002 09:07 PM
