fluttering noise and loss of power at high rpm
Old Apr 5, 2015
siguy2's Avatar
siguy2 is an unknown quantity at this point
my car seems to be making a fluttering/ticking noise when I'm in high rpms and I seemed to have lost a substantial amount of power while in high rpms, not sure what it could be help!
Old Apr 5, 2015
Poopies's Avatar
Super Moderator
Re: fluttering noise and loss of power at high rpm
Is there a ? How is the air filter? The spark plugs? The fluids?
Old Apr 5, 2015
siguy2's Avatar
Yes, the check engine light is for the downstream and upstream o2 sensors, the air filter is a little old but clean and will be replacing it soon, the spark plugs were just replaced, and oil is a little low due to a major leak from the solenoid valve gaskets going bad and or the cam seal, not sure if that has anything to do with it? The sound also gets faster and louder at high rpms.
Old Apr 5, 2015
Poopies's Avatar
Super Moderator
Do you know where the noise is coming from? Is something loose or cracked? You could post a video where we can hear the noise.
Allecr3
May 22, 2015 01:24 PM
Wild Cranker
May 19, 2015 06:10 PM
Aznnp77
Dec 13, 2001 04:03 PM
DaddyFatSacks
Bolt-on Engine Performance
Dec 7, 2001 08:22 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
