2000 DX distributor question
Old Jan 11, 2015
Tampa Dave's Avatar
Tampa Dave is an unknown quantity at this point
Hi all.
Newbie poster, pre-apologize for any forum gaffes.
Elderly friends car, standing for 2 weeks and now a no start.
Have some knowledge and tools.
No spark.
Replaced coil. No help.
Have LED tester and have been probing 8 wire distributor harness in attempt to isolate cause.
According to diagnostic I found on internet, when engine cranked I should get a pulse on 1 or both of the 2 harness wires nearest the firewall.
I'm getting power on LED when ignition in position II but LED goes dead when engine being cranked.
My electrical system experience is a bit limited.
Can I get a confirmation that this behavior is:
1. wrong
2. indicative of PCM/ECM failure
or
3. possibly and ignition key/cylinder short.
TIA.
Dave
Old Jan 11, 2015
mikey1's Avatar
Re: 2000 DX distributor question
are you getting a spark at the plugs?
that would be the first thing i would check,
Old Jan 11, 2015
Tampa Dave's Avatar
Hi Mikey, thanks for reply.
No spark at plugs.
In S. Florida, so no temperature related issues.
I've followed trouble shooting sequence here:
http://easyautodiagnostics.com/honda...system-tests-5
And have reached point 6:
"If the triggering signal is present, the LED Light will light on and off continuously as long as your assistant is cranking the engine."
The LED goes dead when I crank the engine.
Short in ignition cylinder?
Dead ECM/PCM?
Ghosts?
Old Jan 11, 2015
mikey1's Avatar
my first suspicion would be the ECM on the distributor
Old Jan 11, 2015
Tampa Dave's Avatar
Certainly a possibility.
But I think I'm upstream of the distributor at the moment and not getting the signal from the PCM that I am supposed to get coming in to the distributor harness:
"The LED goes dead when I crank the engine."
Dave
Old Jan 12, 2015
Tampa Dave's Avatar
Hi Mikey,
Thanks for suggestions.
Turned out to be the main relay.
So in case anyone stumbles across this thread:
Symptom - No spark, **No Check Engine Light when ignition turned to on**
Cause - Main relay gone bad.
Dave
jtdunn4life
Oct 27, 2015 03:33 AM
SaNdS
Jun 14, 2015 10:40 PM
What_It_Do
May 10, 2015 05:31 PM
rcolosi
Apr 29, 2015 07:48 PM
viper775
Dec 9, 2001 10:52 PM
