2000 civic ex auto wont start
Old 09-28-2012
lnava805's Avatar
lnava805 is an unknown quantity at this point
please help guys....
Ok so one morning before work i went to start my car and nothing no crank engine will not turn no nothing.... so i got a brand new starter swithced it and engine cranks turns but still no start!! ok since my distributor hade warranty i went agead and changed it and still no spark teted all of my fuzs all relays the gas pump and there all good! the only thing thats left is the ECU.... please help one more thing the wires that go to the distributer has no voltage and testing that at the ecu end it doesnt eather so could it be the ecu??????
PS important when i was changing the starter i forgot to unplug the battery and as i was pulling it out a huge spark was made.... i know i should know better!!! I need help and pronto please!!
Old 09-28-2012
lnava805's Avatar
Re: 2000 civic ex auto wont start
does anyone know the problrm of this should i change the ecu please help!!
Old 10-01-2012
teahou's Avatar
teahou is an unknown quantity at this point
Here is what you need to start a car:
1. fuel
2. spark
3. air
4. compression.
Find which one you dont have, and go from there. It sounds like you have no spark at the distributor? Make sure the connectors are in all the way. I would test the fuel pressure just for the hell off it.
If I remember correctly, the ecu sends a .5 volt signal to ignition coil (I may be way off on this, verify first) and if that signal is not there, then yes you may have "let the smoke out of your computer".
usajags84
05-10-2015 08:11 AM
rcolosi
04-29-2015 07:48 PM
shawe90
04-14-2015 07:10 PM
SSMatey
04-13-2015 06:09 PM
silvervtec01
11-04-2001 06:56 PM
Quick Reply: 2000 civic ex auto wont start
