Oil leaking...and leaking.....and leaking....
Old Feb 27, 2011
satown210's Avatar
satown210 is an unknown quantity at this point
I just recently bought this Civic. It drips oil everywhere and smells. The front of the motor and tranny is covered in fresh oil all the time. It looks like it is coming out right by the Vtec solenoid. I replaced the valve cover, Vtec, and distributor seal.....still it leaks.
Any other ideas?
Old Feb 28, 2011
Re: Oil leaking...and leaking.....and leaking....
clean everything up, run the engine and try to find where it is coming from?
Old Feb 28, 2011
satown210's Avatar
I did and I was saying it still seems to be most wet around the Vtec solenoid. The radiator hose where it connects is all wet back there
Old Feb 28, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I had a similar issue and it turned out I had a pin hole in my head gasket. It was shooting oil all over the car.
Old Feb 28, 2011
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
i replace the solonoid o ring and not the gasket and cam cap, my car would lose half a quart each week,
till i replace the vtec gasket and cam cap then it stop
did u replace both of those i know u mention vtec. theres 2 gaskets located on the side of the vtec and one o ring on the solonoid itself so theres 3
Old Mar 1, 2011
satown210's Avatar
what other 2 gaskets are you talking about?
Old Mar 1, 2011
check out my thread that i did last year
https://www.civicforums.com/forums/1...t-replace.html
Old Mar 1, 2011
satown210's Avatar
Thanks but u have a different motor. I dont have caps like that.
Old Mar 2, 2011
lazlong's Avatar
http://www.hondapartscheap.com/south...t=0&quantity=0
Did you replace #11? Sometimes it can be the valve cover gasket or the cam seal.
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
CdnRD
Aug 21, 2015 11:42 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
