civic 1997 horn & brakelights problem
Old Feb 10, 2007
kid1234's Avatar
kid1234 is an unknown quantity at this point
car is 1997 Honda civic 1.4 petrol
The problem is all 3-rear brakelights and the horn are not working at all.
I have checked the fuses, the horn and brakelights operate on the same fuse, but the fuse is ok.
Can anyone offer any help/ advice as to the problem?
Old Feb 10, 2007
CraigW's Avatar
15 Amp fuse #52 in under-hood box ??
Are the hazard flashers working o.k. ?? Does it have keyless entry ??
Old Feb 11, 2007
kid1234's Avatar
fuse is ok, yes it has keyless entry
Old Feb 11, 2007
CraigW's Avatar
Flashers and keyless o.k. ?? They also tap into the same constant power feed line. (different fuses)
I will try to put together some info, It may help you or your mechanic troubleshoot the problem.
No brake lights is not a safe thing.
Edit: From what I could tell the constant power is supplied to the under-hood fuse box and then distributed to the fuses for the constant power devices.
I would also try another 15 Amp fuse #52 just in case, insert and remove the fuse a few times into the holder to help clean up the contacts a bit.
I have some wiring info put together, if you want/need it I can scan it for you. Just let me know.
usajags84
15
Aug 19, 2015 03:12 AM
Linda0818
Apr 23, 2015 11:30 AM
SSMatey
Apr 13, 2015 06:09 PM
NeoMagus
Nov 7, 2001 10:10 PM
NeoMagus
Nov 3, 2001 07:04 PM
