How do you get the headunit...
Old Apr 17, 2003
DMX's Avatar
DMX
DMX is an unknown quantity at this point
to go under the pocket? id rather have it under the pocket to reduce the glare form the sun.
Old Apr 17, 2003
DMX's Avatar
DMX
like this...
Old Apr 17, 2003
TeSt DrIvE's Avatar
TeSt DrIvE is an unknown quantity at this point
What car is this for? Cause in a Civic SI, i dont think it can be done because of some bolts that grip on to the chassis behind the deck. Well at least ive been told thsi by quite a few people so. But jsut try different face kit adapters.
Old Apr 17, 2003
tbone323's Avatar
tbone323 is an unknown quantity at this point
hey DMX, have you ever had your deck above the pocket? Just wonderin on how much that config cuts down on the glare...I HATE the glare on my deck during the day!!
~Tbone
Old Apr 17, 2003
DMX's Avatar
DMX
~Tbone
My headunit is above the pocket right now... i wanted to put it under it but i dont know how.
Old Apr 17, 2003
tbone323's Avatar
my bad, i saw the pic you posted and figured that you had figured it out
Old May 1, 2003
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Actually this is somethign I am thinking of doing with mine too. Seems like there would be a kit for it. There is room for it and the stock metal bracket behind the radio/ac plastic has bolts to screw it down to. So I guess the trick is either to find a kit or make it yourself.
Anyone who finds the kit let us know!
Old May 1, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Just drop it down and use a peice of stereo strap to fix it in place....most HU's should have a bolt hole in the back for a strap. Then you will need fiberglass to make a peice for the front so it looks good, or you could leave it as is without the front peice.
Old May 1, 2003
In my Xterra I used a wood piece for the hole and used the strap you mentioned to mount it in the back and then the bracket on the front, that worked nicely. I'd like to get sometrhing premade for this for the honda tho... I looked around online earlier and saw nothing so far but Im sure someone makes something. If not I will have to whip something up I guess...
Old May 2, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
In the pic that is posted, I'm almost positive that's an American International kit#HONK828 flipped upside down. I know it says it will fit the si, not sure about civics. and it wouldnt fit flush either, it would sit back a little.
djspot
Jun 30, 2004 08:23 AM
half_n_half17
May 5, 2004 05:39 PM
gotti
Dec 18, 2003 02:52 AM
Gryphin
21
Oct 31, 2003 01:01 PM
PopcornPlaya
Jun 16, 2003 06:55 PM
