Hatchback Sub Questions
00 Hatchback Owner
Hey guys, I want to put 1 sub in my car... but I dont want just a little sub that pushs a little, i want 1 monster... I got told to put a JL W7 in there, but then i heard that the w7's sound like rubber... Then I thought ECLIPSE... but I dont know much about Eclipses... I listen to alot of different things so i need a system that can handle the lows of rap, but the highs of some of the rock i listen to.. so if you can suggest some products that can help me do this so i can out do the little punks at school, id love to show thoes $*(%^ up but yea...
Ive thought about a setup, and i want a nice 12", 1 amp for the sub, 1 amp for my front and rear speakers... i got 150 pioneers in the front and 220 in the back... so if you can tell if i need to replace em or what, i also have a alpine CDA-9811 headunit... so now ya know what im working with... so HELP!! :-D
IDMAX, Eclipse titanium or aluminum for a budget, DD audio, soundstream, JL, kicker L7, rockford power hx2 are all ones to look at.
depends on your budget and how clean you want it.
how bought the e12a-$300(on their website)
mtx 801d around $250(on ebay)
mtx 684 4-ch amp $250 (on ebay)
boc, diy to ed's specs $50 on materials
dual amp power kit $50
Rca's $50
TOTAL--$950 (UNDER BUDGET)
Rca's $50
Electric Boogaloo...
yes, im retarted, i just re-read the topic. i was asking about trunk space, but you have a hatchback... im stupid, forgive me. how much space do you have to work with?
00 Hatchback Owner
hmm i duuno the hatch space... and i couldnt tell ya since my hatch is in the shop..
Rca's $50
e12a?
Rca's $50
e12a?
00 Hatchback Owner
i looked around and i really want to put a Eclipse SW-8122DVC , with a 5 channel eclipse amp, anyone know where i can get this? and what the model number is for the amp?
if i knew it'd fit, i'd reccommend a Virtual Technologies Hammer Pro 12 in one of their (VT's) ported enclosures. with a hifonics gen XX Zeus amp running at 4 ohms (1100 watts) and a hifonics gen xx Jupiter 4 channel. 0/1 or 2 ga. wiring kit with distro blocks. and RCA's. should run you under 1000. the sub i know is 199.99 plus 99.99 for box. and i believe that the zeus amp is around 259, and the jupiter around 219. the wires can run anywhere from 40 to 75, depending on how you buy it (cheaper to buy off a roll as opposed to a kit). i have a dealer hookup so i can get my stuff a little cheaper, except the VT stuff. i go manufacturer direct on that stuff.
another setup would be:
Amp: Hifonics Poseidon 5 channel amp (75X4 Rms 4 ohms + 300X1 D-Class 4 ohms) around $400 (if you can find one)
Sub: JL Audio 12W6v2 around $330 (possibly cheaper on e-bay)
Box: around $70 (cheaper to build your own to JL's Specs, provided you have knowledge of building boxes)
Wiring: 4 ga kit around $60 (cheaper to buy off roll, probably 45-50 bucks off roll with rca's)
*with the HiFonics Poseidon you only need one amp for both insides and subs (it provides a 4 channel plus a d-class mono)
there are 2 eclipse 5 channels the
ea3532
specs: max 105X4 (2 ohms) plus 230X2 (2ohms)
60X4 @ 4ohms plus 120X1 @ 4ohms
pa5532
specs: max 125X4 plus 460X1 @ 2ohms
70X4 plus 280X1 @ 4ohms
ea3532
pa5532
Rca's $50
e12a?
Rca's $50
e12a?
Check em out. http://www.edesignaudio.com/
They are also the only authorized dealers of avionnix amps
The LA Clipper
Re: Hatchback Sub Questions
Man, you don't like the way a W7 sounds??!!! That is almost sacrelidge (sp)!!!! Anywayz, to each there own. You should give the IDMax a listen...a very good sub that can be bought for less then $350 from an authorized dealer . You can prolly also get them to price match a another sight like Woofersetc.com to get a lower price.
When I have heard the IDMax I have been very impressed...and I think of all the "super subs" from mainstream manufacturers it has the best price to perfomance ratio.
The LA Clipper
so IDMAX or w7? top of the top which one would you pick?
Martinez8o5
Jul 31, 2015 10:58 PM
beeemerdude
Jul 23, 2015 03:53 PM
suburbanite
Jul 17, 2015 03:05 PM
NoobyKid
Jul 13, 2015 07:53 AM
