newb(ice) question... please help
Old Apr 8, 2003
CivicFerio's Avatar
CivicFerio is an unknown quantity at this point
i'm still new to ice.. so... well i already have aftermarket speakers and hu.. i hav a sub and a mono amp... now my question about the amp wiring is... if i buy an amp for my speakers(front and back).. do i need to buy an amp kit again? i mean do i have to buy the power line? and wire it to the battery(agaiN)? thanks!
Old Apr 8, 2003
LiKEaFeRiO's Avatar
You can buy a power distribution block (i think thats what its called).
And also a ground distribution block.
Old Apr 8, 2003
CivicFerio's Avatar
so what did you do with yours? is that thing like waht you put in the cig lighter socket and you get 2-4 more ac's?i mean is it the same concept?
Old Apr 8, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
This is what you need. Its called a distrobution block. Even Radio Shack sells them.
It will take your existing power wire in the rear of the car and split it for multiple amplifiers.
Depending on the size wire you have run now you might be ok. Tell us your amps and then we can tell you what size wire you need coming to the battery the the splitter.
Good luck.
Old Apr 8, 2003
LudlamTheory's Avatar
i boogie for the raindrops
what size is your existing power wire? what size is your amp, how big is your next amp gonna be?
Old Apr 10, 2003
CivicFerio's Avatar
my mono amp is a kicker 400.1 i haven't really decided on what amp should i buy for my front speakers yet... thanks for your help you guys!
Old Apr 10, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
well.. what kind of aftermarket speakers do you have?? and what kind of HU did you get??
that should help decided on what amp to get
Old Apr 10, 2003
CivicFerio's Avatar
well. i have infinity 605cs at the front and infinity 652i at the back... my hu is a sony cdx-m730...i plan to change this soon though(hu)
Old Apr 11, 2003
with those speakers you will want a 50-75 x 4, also, how big is your sub amp and what gauge wire are you using right now?
Old Apr 13, 2003
CivicFerio's Avatar
... i think its a 4guage.. what do you mean by my sub amp? you mean the kicker 400.1? i don't know the exact measurements but it's not that big... also... i'm having distortion problems(when i trun it up real high-speakers-not the sub).. will an amp eliminate the distortion?
Old Apr 13, 2003
Regularjoe's Avatar
When he said size of the amp he was reffering to wattage.
I have a Kicker 400.1 and a Kicker 150.2 in my car. I run 4 gauge to the back, then split it with the monster splitter I showed you earlier.
If you only had 8 gauge running to the back then you would wanna upgrade it to 4 gauge so it could handle the power needs of both amplifiers.
An amp on you fronts will not eliminate distortion. They can still distort on an amp. No amp or speaker is immune from this. The catch is the speakers will be able to go louder before they do distort.
Old Apr 13, 2003
CivicFerio's Avatar
so it's ok if i go for a bigger guage wire? what if the amp that i will be buying says it's recommended for an 8 guage?
i'm just having problems with my mids.. i love the tweets but the bass on the mids is not good...that's why i thought having an amp for the speakers will eliminate the distortion.. thanks!
Old Apr 13, 2003
Regularjoe's Avatar
Amplifier power wire ratings are a minimum that is recommended.
Any wire bigger is ok.
The point is if you have 2 amps that require 8 gauge there are two options. Two runs of 8 gauge or one run of 4 gauge to the trunk plus a splitter running 8 gauge from there to each amp.
Old Apr 13, 2003
CivicFerio's Avatar
oh ok! how much did you pay for that(your distribution block)?
Old Apr 13, 2003
CivicFerio's Avatar
and where is the ideal place to put it? thanks!
Old Apr 13, 2003
Konger's Avatar
Konger is an unknown quantity at this point
I would go with a kicker kx300.4 amp for the 4 interior speakers. Run 4 gauge wire from the battery to the distribution block then 8 gauge from the block to the amps. Make sure you ground both amps with 8 guage wires. You can build an amp rack for your amps and mount the block by your amps for looks. Then if you want also put a neon stick to accent your amps at night.
Old Apr 14, 2003
CivicFerio's Avatar
yeah i plan to do that.. look at regular joe's trunk... i don't like neons though
IronFist
Sep 25, 2015 07:13 PM
chadds
Sep 9, 2015 05:26 AM
adamdrives
15
Aug 8, 2015 08:53 PM
AlexLx
May 13, 2002 02:53 AM
BeefMan
Bolt-on Engine Performance
Mar 18, 2002 04:56 PM
