A Cap and a Distribution Block
Old Apr 7, 2003
toadsteraz's Avatar
toadsteraz is an unknown quantity at this point
Question A Cap and a Distribution Block
Ok, so I have a huge distribution block, a 3 farred cap and two amps. I was wondering if anyone had any response on how these should be conencted together. I have been told to run the cap off a cable running from the distribution block, I have been told ti run the cap before my distibution block and also after my block. The one that sounds more obvious to me is running it before the block. Does anyone have any feedback they can give me on what would be the best option. Thanks a lot. I appreciate the help!
Old Apr 7, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
from the distro-block you can run it to the pos of the amp then ground the amp to the car. you will be fine.
Old Apr 7, 2003
LudlamTheory's Avatar
i boogie for the raindrops
what i would do is just sell the cap and run it without it
Old Apr 8, 2003
toadsteraz's Avatar
Well after the block would make little sense. The reason is becuase I have only 1 cap. I have two amps. So do I connect the cap before the distribution block? Or do I connect it to one of the positives on the block?
Old Apr 9, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Connect it before the block, preferably within 12 inches if your amps. (12 inches of wire length, that is. Not a huge deal though....)
Old Apr 9, 2003
WhiteRabbit's Avatar
doesnt really matter where you put it, as long as the cap is grounded and hooked to teh D-block
Old Apr 10, 2003
fonto's Avatar
The LA Clipper
I have my cap connected about 4 inches before the distro block...is that bad? Honestly i really do not feel like moving anything in my car right now...so as long as my car won't catch afire I will leave how it is if it is ok.
Old Apr 11, 2003
your fine. electrons seriously move at like 1/10th the speed of light. PLENTY fast
Old Apr 11, 2003
fonto's Avatar
The LA Clipper
Thanks for the piece of mind, 'cause I don't even feel like messing with my system right now.
Old Apr 11, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I have a cap that has a distribution block built in. I have 1 4 channel amp so I run 0 guage ground/positve to the cap, the 4 guage to my amp. It is really easy. If you have more than 1 amp, just hook the cap up as if it were another amp, in parallel with everything else. I recommend getting a cap with a digital display so you can make sure your voltage doesnt drop too low when the bass hits.
ayoitzjulesdx98
Feb 26, 2016 10:44 AM
USCGBM
Aug 12, 2015 04:22 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
Smokahontas123
Jul 22, 2015 10:07 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
