how do i hook it up?
sorry bout that post! will it sound ok if i hook up my front speakers to an amp, and some subsup to it. then run the reart speakers to the hu? my head unit only has one set of preamps so how do i hook it up?
are you running the subs and fronts off the same amp? or one amp for subs, one for fronts? cuz if you get an amp w/ preamp outputs you'll be cool w/ the 2 amp setup. or else you might need to use some sort of splitters to complete the install for a 1 amp setup (don't think that would cause a significant SQ hit, since the preamp voltage would be the same, not sure what effects the addition current would cause though [IMG]i/expressions/face-icon-small-confused.gif[/IMG]... someone correct me if they know).
Hutch1051
Sep 29, 2015 09:20 AM
PunX
Sep 23, 2015 10:45 PM
pilebuck13
Sep 21, 2015 10:45 PM
sch2cm
Jul 21, 2015 09:58 PM
