DIY: Front Speakers
Old Jul 29, 2002
DowntownRicer's Avatar
DowntownRicer is an unknown quantity at this point
DIY: Front Speakers
Okay, to start off i pretty much am a newb when it comes to hands on stuff with your car. I know parts but not a damn thing about doing the installs.
With that said, i have a question. Is there some kind of adapter or somethin that i can use to get some 6 1/2's in the front doors. I tired using the one that came with the speakers but its too big. First of all, Will these Fit? Second, what should i use to make it fit?
P.S. If you can refer me to a nicely detailed DIY it would be much appreciated ( I don't need to know how to get everything off of the side of door, i just need to know exactly how to mount the speaker.)
Old Jul 29, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
well.. first of all it doesn't do us any good if you don't tell us the speaker you're trying to install.. secondly, yes.. either way you're going to need an adapter, can be bought from crutchfield.. also since i dont' know what speakers, some 6 1/2's need to have the door cut a little in order for it to fit.. if it's too deep, it won't fit either.. max is about 2 3/16 and that will barely fit with a spacer and without getting in the way of the window.. .lastly.. you might want to post in the ICE forum next time.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 29, 2002
Well i have some Pioneer 220 watt TS-A1767, They look like they will fit i just need a proper spacer. You Say i can purchase one from crutchfield, so i might as well head on over there. Thanks
Old Jul 29, 2002
ricewashed's Avatar
ricewashed is an unknown quantity at this point
IT helps to search for websites related to what you are looking for. It is the smart thing to do, but then again not a lot of people are bright.
Old Jul 29, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
All you need is a 1" spacer, and a speaker harness 72-7800, you might have to trim the plastic lip on the door, I had to when I installed my speakers.
Old Jul 29, 2002
Grey's Avatar
DIY King
I have oversized speakers in front. 6.5" I used the Scosche universal speaker spacer. SS65. I also used some XTC foam baffles and a Metra harness to go into the stock plug. Works pretty good, although the XTC foam baffles are a little too big, so they hit the back edge of the door. I might get 5.25" XTC baffles and see if those fit a little better.
Old Jul 29, 2002
DogstyleEX's Avatar
hey grey.. do they actually help.. i installed mine with the foam baffles, all it did was create a rattle.. plus the bass response wasn't as good either.. so i took it out and it now it has much fuller bass.. instead, i just wrapped dynamat around the hole.. because the baffle also served as a spacer in addition to the one i had.
Old Jul 29, 2002
Grey's Avatar
DIY King
Yeah, mine improved the mid range bass, but reduced the low end bass. Plus since they sit up against the back they do make a rattle. Exactly like yours do probably. That's why I want smaller ones. Well, less deep. Whatever.
Old Jul 30, 2002
Jimmy Chang's Avatar
Jimmy Chang is an unknown quantity at this point
when i put my speakers in i didn't buy an adapter i just to the stock speakers and cut the speaker and the back plastic out then took some long screws and screwed the speakers straight to the door. did the same for the back speakers too to allow the magnet to miss the trunk hangers.
Old Aug 3, 2002
Hey, how did you do this, if you could give me a diy about it it would be great
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
General 7th Gen
Jul 9, 2015 10:17 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
