Rca Cables
Old May 23, 2002
Crash2002's Avatar
Crash2002 is an unknown quantity at this point
Rca Cables
Should i run power on the right side and rca's on the left? whats the most common setup? and if i run them on the left how am i going to get the moldings off where the trunk release and gas door release is?
Old May 23, 2002
mohawkboom's Avatar
Power down the right.. RCA's down the left.. ground to the rear seat bolt. Do not cross any RCA's and power wires..
Old May 23, 2002
Crash2002's Avatar
cross any rca's? you mean like get them confused or actually cross them
and how do i take off the driver side moldings where the trunk release is?
Old May 23, 2002
mohawkboom's Avatar
I mean don't cross the power wire with the RCA's... just pull off the little plastic cover..remove the screw..and pry off..
Old May 23, 2002
Crash2002's Avatar
last time i had my stereo stuff installed it sounded like alternator whine comming from the speakers how do i make sure that wont happen this time
Old May 23, 2002
mohawkboom's Avatar
By not having the RCA's in contact to or even close to the power and ground wires [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 23, 2002
Crash2002's Avatar
it still makes that noise with teh stock stero and aftermarket speakers no amps
Old May 23, 2002
mohawkboom's Avatar
that's just not right.. shoudln't do that really...not stock..
Old May 23, 2002
Crash2002's Avatar
i have the aftermarket speakers in there though, could my speaker wireing be making that noise?
Old May 24, 2002
mohawkboom's Avatar
the only way RCA's will pick noise from speaker wires is if they are unshielded..or your running about 300 watts through the speaker wires..
Old May 25, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
I think mecp recomends that you have your rca and power wires at least 18 inches apart from each other or you get noise
Old May 25, 2002
aldini's Avatar
aldini is an unknown quantity at this point
Have any of you guys ran your wires through the center console? I have my power through the passenger (4 gauge) and I ran my RCAs through the center console...
Old May 25, 2002
WhiteRabbit's Avatar
alternator whine can also be cause by a bad ground, make sure that your ground point is a good connection....
strange tho that it is heppening with a stock deck, and no amps....... curious.......
Old May 26, 2002
Crash2002's Avatar
i dont get it either, oh well ill have to live with it
Old May 28, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
#1 Go buy a better RCA cable...
#2 Buy a better ground
#3 Make sure you have no paint between the ground connector and where it touches the car for the grounding point.... (SAND IT OFF if you need to)
My $.02
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
IronFist
Sep 25, 2015 07:13 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
redcloud
Sep 7, 2015 01:45 PM
