Immobilizer Antenna?
Old Jan 26, 2019
mac25's Avatar
Dr Krieger of Modification
Hey all, while installing some new gauges I found this loop of wire which I'm guessing is an immobilizer antenna. However I thought the oem unit is a plastic loop and box.
perhaps aftermarket?
Old Jan 26, 2019
Re: Immobilizer Antenna?
The OEM has its 'antenna' loop embedded in the plastic ring around the barrel of the ignition lock (you're staring at it)
That wrap or wire you discovered----follow it to its origin and I bet it's gonna lead you to an aftermarket (remote start??) unit
Old Jan 26, 2019
mac25's Avatar
Perfect, thx @ezone , I'll check it out later.
beetlevegas
Audio DIY
Oct 3, 2012 05:36 PM
kahala
Aug 23, 2011 03:14 AM
LegitBaLLinCivic
21
Dec 11, 2007 03:24 PM
alexirene
Nov 10, 2006 08:45 AM
civicr34
Nov 3, 2003 11:12 PM
