dash blank - what goes here?
Old Sep 21, 2014
arrrz's Avatar
arrrz is an unknown quantity at this point
New to me 01 Civic EX. Trying to figure out what the factory/dealer option would be that goes in this dash blank.
Old Sep 21, 2014
arrrz's Avatar
Re: dash blank - what goes here?
Or even better would be if anyone can point me to a USB socket that would fit nicely.
Old Sep 21, 2014
It's a switch blank.
Foglight switch went there on some of the dealer accessory kits.
Put whatever you want in there. Modify the insert to your hearts' content.
Old Sep 22, 2014
CraigW's Avatar
Cluster swap (mileage will stay with each cluster) Common on early models.
Old Sep 22, 2014
mikey1's Avatar
just buy a USB adapter that fits into your lighter socket,
i have seen them as cheap as 2 bucks.....much easier
Old Sep 23, 2014
arrrz's Avatar
Fully intend to mod away. But if I can find an OEM switch for what I want, I like to go that route. And it sounds like there is. Thanks.
Old Sep 23, 2014
Erf_Em2's Avatar
Erf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of lightErf_Em2 is a glorious beacon of light
Buy a Type A to MALE TO FEMALE USB jack, and then mount it next to the handbrake where there is a small plastic trim that easily pops out. That is what I did alongside an AUX. the reason is you can upgrade your head unit to one of those touchscreens with the AUX and USB at the rear, and it will be a really clean look and convenient.
Then for wiring run a 6'ft USB and 6ft AUX under the plastic trim, and hook it up to the back of your head unit. Now this only works well if your head-unit has inputs at the rear.
I bought the 6 foot USB Jack and AUX Jack from this Malaysian website and it is nice and thread locking attachment procedure.
Here is my setup
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
