Adding power adapter near visor
Old Mar 11, 2013
bryan11's Avatar
bryan11 is an unknown quantity at this point
I'd like to add a 12V power wire near the rear view mirror that's off when the car is off. I could tap into the wires from the cigarette lighter, but how does one get the wire up through the door pillar toward the rear view mirror?
Old Mar 11, 2013
GolNat's Avatar
Prelude Owner
Re: Adding power adapter near visor
If you remove the driver side a pillar you can slip the wire from under the dash up to the pillar and run it across the front of the headliner. Once you get the pillar off (it pulls off) you take a coat hanger and shove it down the hole that you will see between the dash and pillar. Take the wires that you tapped into the lighter with and tape or tie them to the coat hanger. Pull the coat hanger out and the wires will follow.
Old Mar 11, 2013
bryan11's Avatar
Okay, that doesn't sound that bad. I had not seen any info on how to remove the pillars. Are there possibly any videos on doing this?
Old Mar 11, 2013
GolNat's Avatar
Prelude Owner
Not any that I know of. It's really easy to remove. You just need to pry it off with your fingers or an interior trim tool (flathead). Start at the top near the headliner and glass.
Old Mar 11, 2013
bryan11's Avatar
Okay, I'll try it. Thanks much.
Old Mar 12, 2013
CraigW's Avatar
For a constant voltage LOW CURRENT source that is already up there... use the map lights, or the dome constant 12 volts.
Add a very low current inline fuse possibly. (3-5 Amps)
Dani1993
Jul 24, 2015 09:02 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
beeemerdude
Jul 10, 2015 09:22 PM
ZILLA
Jul 10, 2015 06:05 AM
ZILLA
Jul 5, 2015 05:24 PM
