Headlight/key buzzer alert broken
Old Aug 14, 2012
mfskarphedin's Avatar
mfskarphedin is an unknown quantity at this point
Question Headlight/key buzzer alert broken
Hi, the alarm buzzer that sounds letting me know my lights are left on is broken. I keep forgetting them on now and need a jump. Should be a simple fix? But I'm not sure where to start. A fuse maybe? Thx for any help!
Edit: the front dome doesn't come on either. Switch in the door???
Kristen
2002 EX, 4 dr.
Old Aug 14, 2012
SpeedDownZone's Avatar
Re: Headlight/key buzzer alert broken
It should be a fuse under the driver side dash.
Old Aug 15, 2012
CraigW's Avatar
Make sure your dome light comes on when the drivers door is open.
Old Aug 15, 2012
Yes, I believe the dome light still works. Nothing went out except the ability to ding when the door is open and the key is in the ignition and/or the lights are on. It does ding sometimes for something else, so that part isn't broken. Think for the seatbelt.
I did check the owner's manual, and it didn't specify a fuse for that. Unless someone knows which one to check, i guess i'll have to check them all.
And hey, you never know - I might find why the a/c and air bags aren't working.
Thx,
Kristen
Old Aug 15, 2012
CraigW's Avatar
Along with testing the dome w/drivers door, also make sure your dome comes on when you shut off the car and remove the key from ignition.
These will test 2 of the required switches.
Old Aug 15, 2012
Just tested that. Didn't come on when i opened the door - only when i took the key out like you suggested.
Old Aug 15, 2012
CraigW's Avatar
[QUOTE=mfskarphedin;4613544]Didn't come on when i opened the door QUOTE]
There is a plunger switch (black rubber cover) on the body, in the area where the door meets the body.
See if it still intact (they can get broken easily)
Look at passenger side for reference.
Old Aug 15, 2012
Found the door switch. Disconnected. Dunno if i did that, but i'm having a hell of a time fishing it out without a second pair of needlenose pliers.
Oh, found the fuse to the a/c blown, replaced it, still no cold air. :/
Old Aug 15, 2012
CraigW's Avatar
If needed you can swap the passenger side switch over to drivers side until you can get a new switch (if defective)
Old Aug 15, 2012
Finally fished it out with the help of a guitar string. The clip is broken, so that's why it fell in. I pulled the switch out and will get one at the auto parts store when i get a few bucks. Thanks for the help! Kinda pleased with myself, hah.
Crazygrlinak
Oct 8, 2015 05:06 PM
Dave Brabant
Sep 9, 2015 08:11 PM
amrhamed
Sep 1, 2015 06:27 PM
mishima
Aug 22, 2015 06:32 PM
