05 Cluster Issue (DX)
Hi everyone, just bought a Civic Reverb 05. So Far I love the car, however I have two questions. One is the mechanic I bought the car off changed the cluster because the first one died and the fuel gauge and temperature gauges work, but are always lower than they should be. For example, on a full tank of gas the fuel gauge shows 3/4 full. It doesn't have to be fixed already but any ideas what this could be?
Occasionally the tach will get stuck for a second at 3000rpm but then quickly correct itself.
I know how to remove the cluster but is there something I could check for, would bad connections cause this issue?
Re: 05 Cluster Issue (DX)
Yeah, they are both completely consistent, just too low down, like when I start the car, the temp line is almost an inch below the bottom line but comes up to 1/4 of the way up.
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Check the connections in the back, make sure its all clean, Did they reset the ECU since they changed it? try that and see if it fixes it.
I reset the ECU but it has only gone through half a tank of gas so far, I noticed that when I filled up with more gas that the line was closer to the top, however, not all the way. Maybe your idea about the ECU makes sense.
It make take a little bit for it to get used to it again. Hope it works out for you. If it doesn't then we can look deeper.
HiImBrandon
Jun 1, 2015 07:34 AM
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
One_PeeJay
May 17, 2015 05:31 PM
