Driver Door only locks sometimes
Old Oct 19, 2011
eazy42's Avatar
eazy42 is an unknown quantity at this point
So originally the door wouldnt lock with key or button (i dont have remote). the little red tag moves up and down slightly, but never actually locks. i can always open the door. every once in a while, if i use the button, it will actually lock. however when i exit the car and press button again, it doesent lock....
sorry for the repetitiveness.
Is this the actuator? or maby something is just loose? btw the whole door panel is not attached very well on the bottom (looks like some botched DIY work)
Even odder, my key does not lock/unlock the passenger door. it seems it doesent even fit. it works for the trunk, but not to unlock the seats, or the trunk lock by the gas/trunk popper. does this have something to do with it?
They key is NOT a factory key, there is no honda emblem or engraving on it.
Old Oct 20, 2011
amatias's Avatar
amatias is an unknown quantity at this point
Re: Driver Door only locks sometimes
sounds like the actuator, my driver door has the same symptoms. had the same symptoms on my pass door a few years back until i replaced the actuator. just lazy to fix it yet
h4ldol
Jun 3, 2015 03:26 PM
Billybob1963
May 31, 2015 07:37 PM
MamaBear2015
May 18, 2015 07:37 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
