how to wire this sub
Old Apr 28, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
ok ive got everything done except how to wire the sub to the amp, ive got an eclipse dvc with the terminals on either side of the sub and a 1000w class d memphis amp. i just want to know the correct way to wire this sub to the amp. ive done a lot of systems b4 i just havent ever messed with a dual voice coil sub b4 and i dont want to mess anything up
Old Apr 28, 2002
jamesbbh's Avatar
come on somebody help me i already have evreything done i just need to hook it up on the wqebsite it says the sub is (4+4) w/e that means
Old Apr 28, 2002
mohawkboom's Avatar
well the Memphis ST1000D puts otu full power into a 1ohm load. You can wire your subs to a 2ohm load, in which the amp will only put out 600Wrms..
Old Apr 28, 2002
jamesbbh's Avatar
if i had the terminal on the amp into a 1 ohm load then what would i do on the sub?
Old Apr 28, 2002
mohawkboom's Avatar
Nothing.. you don't set the amp to any ohm loads.. the ohm load presented is that of the subs voice coils..
Old Apr 28, 2002
jamesbbh's Avatar
ooo i gotcha
ur the god of audio
Old Apr 28, 2002
mohawkboom's Avatar
Ahem noooo read the sig!!!
he he he
Thanks tho.
Cheers
Mohawk
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
