Headlights
Headlights
Hi,
I have a 2003 Civic and the low beam headlights quit working just out of the blue. I've checked all the fuses and all the other lights work. The actual bulbs are not that old. Anyone have an idea what's up? My little repair manual doesn't cover things like this.
Thanks
Thanks
Re: Headlights
I have found other people with the same problem saying there is a recall on this issue? Anyone know about that or what the recall number is? I looked and didn't see any recall on this matter or how to fix it.
Re: Headlights
did you actually change the bulbs? if both bulbs are put in at the same time, it's reasonable that they both burn out at relatively the same time. happened to me.
Re: Headlights
Yes, make sure to double check your bulbs.
The recall deals with the terminal for the low beams at the connector going to the headlight switch (they are provided a ground path to light them)
They made some changes to the 2 bulb setups wiring on later production (added another relay and such)
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
