R.I.P Fogs
Old Jul 8, 2010
e-teckk's Avatar
e-teckk will become famous soon enough
R.I.P Fogs
Got them done Monday and they worked like a charm...didnt drive at night tuesday or wednesday so i didnt turn them on and i go turn them on tonight and they dont turn on -__-
the switch lights up so i know it cant be the switch...any ideas?
Old Jul 8, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: R.I.P Fogs
Check your ground
Old Jul 8, 2010
Re: R.I.P Fogs
bulbs still good?
Double check your wiring is still good/in tact?
Does the relay click when you turn the switch on (assuming you're using a relay)?
Old Jul 8, 2010
e-teckk's Avatar
Re: R.I.P Fogs
i checked the wiring and everything seems intact (though i didnt check if the fogs were still connected to the harness)....i guess ground and relay i'll have to check tomorrow, they can become bad that fast? worked perfectly turning on and off just 2 days ago unbelievable lol
appreciate the quick replies
Old Jul 8, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: R.I.P Fogs
Maybe you reversed the wiring and blown it?
Some LED's light up once, and they blow out right after if ground and 12v were reversed
Check the bulbs
And if they're fine, try directly connecting it to 12v source and grounding it it properly
see if they light up
If they do, its something between the lights and the power source, prolly relay
Old Jul 9, 2010
e-teckk's Avatar
Re: R.I.P Fogs
i checked the grounds and they were fine, fogs also seem to still be connected to the harnesss.. how do i check the relay?
Old Jul 9, 2010
Re: R.I.P Fogs
It should click when you turn your fog light switch on.
Old Jul 9, 2010
Re: R.I.P Fogs
also, if you don't have a multimeter, you should pick one up. You can use that to see if the relay is working without having to listen for the click. just connect the positive lead to the 30 post of the relay and the other to a chassis ground, flip the foglight switch, and see if the multimeter is indicating ~12 volts.
either that or use the resistance checking mode of the multimeter, connect one lead to the 30 post and the other to the 87 post. When you flip your foglight switch, it should display some random value, then settle out to something like .3-.4 ohms.
Old Jul 10, 2010
e-teckk's Avatar
Re: R.I.P Fogs
im gonna use the multimeter to check out the relay...just been too lazy to do it today lol actually i got some touch up painting done though soooooooo yeahhh
Old Jul 10, 2010
sup_mario's Avatar
sup_mario is an unknown quantity at this point
Re: R.I.P Fogs
Check your bulbs and the wires/cables too.
Old Jul 11, 2010
e-teckk's Avatar
Re: R.I.P Fogs
soooo i went to check the relay and the relay was fine, i went to go bolt it back on (its the same bolt where i used a ground) and my neighbor came over and i dropped the bolt inside somewhere....soooooo i put a new 1 in and BAM!!! the fogs worked lol so i guess it was a ground after all
Old Jul 11, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: R.I.P Fogs
sweet! glad its fixed
Old Jul 11, 2010
e-teckk's Avatar
Re: R.I.P Fogs
thanks
funny too cuz you called it from the beginning
Old Jul 11, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: R.I.P Fogs
Sometimes I get lucky
UltraHDGames
Jun 8, 2016 05:16 PM
mrwhos
Aug 11, 2015 02:03 AM
j-chest
Jul 31, 2015 01:18 PM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
