subwoofer/am wiring?
Old Jun 11, 2010
antok86's Avatar
antok86 is an unknown quantity at this point
is there any DIY guide on running wires for your amp and sub? i found the DIY for the head unit but i didnt see one for running wires from amp to battery etc. im gonna be doing my first sub install on my car. i had my headunit installed at circuit city but want to try installing my sub / amp
Old Jun 11, 2010
Re: subwoofer/am wiring?
there's a rubber grommet that you can poke through with a screwdriver. It'll fit a 0ga wire. Fishtape is your friend.
I have power wires running from the battery, through the grommet, under the passenger side doorsill, behind the plastic piece on the rear passenger side to the amps in the back passenger side of the trunk.
My audio wires (RCA and speaker wires) are routed up and over to the back driver side, under the rear seat, under the carpet, through the center console to the head unit.
Keep your power and audio wires separated as much as you can
Old Jun 11, 2010
https://www.civicforums.com/forums/2...vic-coupe.html
No pics, but it'll give you an idea
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
