How to extend battery cables?
Old Jul 30, 2008
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I searched and found that 4 gauge wire is the correct size but what kind of connectors do I use if I'm trying to extend the power and ground cables that connect to my battery? So a connector connecting stock battery cable/wire to my new battery cable/wire. Thanks for the help.
I was considering the JL Audio Master Fuse Block - XB-MFBU-ANL.
Link:
http://mobile.jlaudio.com/products_c....php?cat_id=11
Old Jul 30, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: How to extend battery cables?
Couldn't you just cut and solder? Or wrap with electrical tape.
Old Jul 30, 2008
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Worse advice ever!
This isn't a little wire we're talking about. It's 4 gauge! If you haven't seen it, it's the size of your thumb. It's unsafe and impractical for a wire this size to be snipped and taped. You'd be better off buying that fuse block. It'll serve two functions for the price of one: To connect your wires and protecting your equipment with the fuse.
Old Jul 30, 2008
agree, that thing you posted looks like it will work fine.
Old Aug 7, 2008
Elix1r's Avatar
Elix1r is an unknown quantity at this point
I have that exact fuse and it works like a charm. I ran my positive 4 gauge wire through the passenger side grommet and then hid the fuse behind the small lower panel next to the door. I then ran it to a distributor block that split into 2 8 gauge wires for my amps. Very easy and clean if you are willing to take off interior panels with the wonderful DIYs on this site.
Uan
Aug 23, 2015 03:03 AM
geforce789
Aug 19, 2015 06:17 AM
JetsterDajet
Aug 16, 2015 01:56 PM
muttleytm
Jul 11, 2015 06:00 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
