l.e.d. under dash help
Old Jul 2, 2008
meiseman's Avatar
meiseman is an unknown quantity at this point
I got 2 9" optx l.e.d. strips as a present and want to put them under the dash like where the pedals are and the same place on the passenger side in my '04 LX sedan, but I have no idea how to do it. Can anyone shed some light on how to hook up the L.e.d. strips??
thanks
Old Jul 2, 2008
TRIZ's Avatar
Re: l.e.d. under dash help
If they are 12v, just pull out the area with the cig lighter and use some wire taps- get a switch and feed the red wire to the power in on the switch, and put the power out to the led strips, and ground it. Mount them however you want, and your set. Just when you go to get a switch get a simple on off switch with three prongs- power in, power out, and ground. It gets tricker if you want them to come on when the doors are open and stuff like that... then you'd need a relay and have to sit down and think about it for a minute.
Old Jul 2, 2008
meiseman's Avatar
ALright. that sounds good, but i have two of them and they are both 12v so what do i do? i read somewhere about hooking up to the battery but i had no idea what it was talking about.
Old Jul 2, 2008
Alex857's Avatar
Alex857 has a spectacular aura aboutAlex857 has a spectacular aura aboutAlex857 has a spectacular aura about
take out your cig lighter, and wire it up there. i ran wires over to a switch i put where my blank thing is where the fogs switch is suppposed to be (by cruise). Ill put pics up later. I have the same lights in my car, red and all. ill get some pics and guide you through it if you want. Just pm me though, it will be alot easier to get ahold of me that way
Old Jul 3, 2008
SSMCivic2k5's Avatar
SSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura aboutSSMCivic2k5 has a spectacular aura about
i have a switch for my strips...will post pics later on
Old Jul 3, 2008
meiseman's Avatar
Alright cool, sounds god everyone. Thanks for all the help, and pictures would be awesome
Old Jul 3, 2008
TRIZ's Avatar
I have ccfl tubes that I bought a long time ago with plans to put in the foot wells to go off when the doors are opened- taped off the dome.
Old Aug 15, 2008
316's Avatar
316
316 is an unknown quantity at this point
Smile Re: l.e.d. under dash help
Here is a good website that i used when i was doing my LED lights inside my car. Its a step by step guide lines .... Hope that helos you, Good luck.
http://www.all-neon-car-lights.com/h...ar-lights.html
Old Nov 23, 2008
lakerecrider's Avatar
lakerecrider is an unknown quantity at this point
I use the color changing door handle kit in my civic hybrid and that is super slim, bright and color changing. They also fit into most areas where you can't fit a tube.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
frank_kleng
Sep 29, 2015 10:55 PM
