how to test door actuator?
Old Dec 7, 2007
muon_liem_em's Avatar
muon_liem_em is an unknown quantity at this point
My 2002 civic couple driver side door lock doesn't work. All the fuses under hook and desk are still good. So I think maybe the door actuator. I am going to take it out tomorrow. Is there a way to check it to make sure that is the problem before I order one?
Thanks a lot.
Old Dec 7, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: how to test door actuator?
get in car and close the door.
press the power lock button...
if your passenger side locks and unlocks and your driver side doesnt move its your accuator
Old Dec 7, 2007
that is exactly what happen to my car.
Old Dec 7, 2007
02BLKCIVIC's Avatar
door lock actuator...
28$ part
Old Dec 7, 2007
my local Honda has it for $50.
wish me luck tomorrow. temp is about 15F here.
thanks a lot.
Old Dec 7, 2007
CraigW's Avatar
The service manual just says to quickly apply and remove voltage to the leads of the actuator. Actuator un-hooked (isolated from wiring harness) Reverse leads (polarity)for up/down operation.
The passengers side in my 05 keeps getting slower and slower, I may need one soon.
Old Dec 7, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
yea i just got mine done. $40 for the part, 60$ for the labor.
Old Dec 7, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Use your meter to see if the correct polarities get there at the right times. Both wires will rest at ground. One will go to 12V in lock, the other will do 12V in unlock. If this all happens it strongly implies the actuator.
At that point, like CraigW said, apply 12V to one side and ground to the other and see if there is any response.
Old Dec 11, 2007
I spend at least 3 hours in the cold to replace it. No room to work on, that damn actuator lie between 2 door frame and i only able use one hand only. Maybe it only happen on '02 EX cp.
DerbyDad03
Exterior
May 16, 2021 10:07 AM
h4ldol
Jun 3, 2015 03:26 PM
vgon24
May 12, 2015 09:16 PM
Killagi
Apr 12, 2015 10:42 AM
CivicEX2k1
Jan 4, 2002 01:47 AM
