M3 power mirror wiring.
Old Nov 11, 2007
94shadow's Avatar
94shadow is an unknown quantity at this point
Hello, I'm new to this site and I don't know exactly how to post a message or thread.
I bought a set of power mirror with LED's and I can't wire the mirror. I have the LED's working.
I need help in wiring the power mirror. My civic did not come with power mirrors so I don't have the stock wiring harness for the mirrors.
If anyone knows how to run the wires for the power mirrors and what parts I'll need, I'll be forever greatfull.
If anyone out there knows how to do this set-up, please help!!
Does anyone has a diagram or schematic, could you please post itcso I'll be able to get my mirrors working.
Thanks,
94shadow
Old Nov 11, 2007
bigainabuilt's Avatar
Runumhard Or Go Home
bigainabuilt is an unknown quantity at this point
Re: M3 power mirror wiring.
https://www.civicforums.com/forums/2...or-wiring.html Welcome!! Hope this helps. Search is your friend!!
Old Nov 11, 2007
94shadow's Avatar
My car does not come with electric mirrors so there is no switches, harness or connectors for the mirror.
I'll need to get the wires somewhere from the harness under the dash.
The repair manual hardly shows anything about power mirrors.
The wires for the mirrors are:
RED
WHITE
BLACK
The LED's were easy to install.
Still looking for help....
H E L P !!!
94shadow:
confused:
Old Nov 12, 2007
speedfoos's Avatar
If your car did not come with electric mirrors and you have no switch to control your new, aftermarket mirrors, what are you going to wire them to?
I may be missing something here, but you need to get a power mirror switch, the appropriate relays and completely wire in your new power mirrors. No easy task, but it possible. If you can get the mirror switch for your car (which is?) then it should just be a matter of providing 12V to the switch and figuring out the output.
This sounds easier than it will actually be.
Old Nov 12, 2007
94shadow's Avatar
I know it's going to be hard but I have a lot of time on my hands since I'm retired.
I have an Integra mirror switch but it is different from the civics. I couldn't get it to work.
Went to a couple of junkyards but couldn't find any civics with the switches, connectors and relays.
I am also looking for an aftermarket mirror installation kit
like the ones they have for windows, locks, etc....
Thanks for the response.
I'll keep on trying...
Old Nov 13, 2007
speedfoos's Avatar
Tell you what. You find the switch and I can get you the wiring diagram on how to make it work. What year/make/model Integra did the one you have come off of. We'll start there. Cool?
Old Nov 13, 2007
94shadow's Avatar
I don't know what year the switch is for but it is a JDM honda power folding mirror switch EK DC CD EP BB DB.
This is the only description I can give you.
The wires on the back of this switch runs straight on the connector. In the repair manual it is compatible with the integra switch.
The civic switch in the manual shows the wires go in a U type pattern.
This is all the information I have.
I hope you can understand what i've written.
Thanks for all your troubles. I hope this makes sense.
Mahalo,
94shadow
Old Nov 16, 2007
94shadow's Avatar
Unhappy Re: M3 power mirror wiring.
Hello again......
Well, I guess no one knows how to wire a power mirror that did not come with a switch....
Does a different type switch make that much of a difference?
Well, I guess I'll have to find the wires myself.
Thank you all.....
Old Nov 16, 2007
CraigW's Avatar
2 motors used, 2 wires each 1 motor for up/down & 1 motor for left/right movement. Direction of movement will depend on how the + & - polarity is applied to each motor.
To use the switch you have you should have a schematic for original vehicle to determine the pins on the switch. Or a DMM, paper and pencil to draw up a layout for the pins and some time to figure it out.
Locating a mating plug for the switch, getting wiring it into the doors... ????
If you want the mirrors schematic for the 7th gen Civics to use let me know, I can send it via E-mail.
Old Nov 16, 2007
94shadow's Avatar
Thumbs up Re: M3 power mirror wiring.
Thanks a lot for answering my e-mail.
I would be forever greatful if you could send the wiring diagram.
I have an integra switch but it is different from the civic DX switch.
I bought a switch and relay from e-bay and it should be arriving shortly.
I was losing hope but, thanks to you I have hope again.
94shaow
I AM FOREVER GREATFUL!!!YOU ARE A LIFESAVER.....
MAHALO NUI LOA!
(THANK YOU VERY MUCH) meaning for above.
Old Dec 9, 2007
94shadow's Avatar
Hello again,
Got my mirror to work but it wasn't easy.
so there wasn't any wires or relays.
I found a way to hook up the wires and now
it is working perfectly.
Thanks for everyones help!
Gotta go now...
94shadow
Old Aug 23, 2009
tony_champ10n's Avatar
tony_champ10n is an unknown quantity at this point
hey i know its been like two years but i jst bort a 2000 civic cxi with manual mirrors and my brother smashed the left side so i was deciding to install power mirrors could you please helpme with this like postin instructions and pictures
Old Aug 23, 2009
Alpha 5's Avatar
Do you have the mirrors yet? I have some for sale.
You will also need all the wiring and the switch.
Old Aug 23, 2009
FALKEN's Avatar
Civicforums Junkie
moved.
Old Aug 23, 2009
Alpha 5's Avatar
The thread is 2 years old and you are moving it now.... lol.... OK.
Old Aug 23, 2009
falken moves more threads than all the other mods combined lol
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
GotSiR
Jun 23, 2016 04:06 PM
sch2cm
Jul 21, 2015 09:58 PM
breanna_17
Jul 21, 2015 04:01 PM
igorbogu
Jul 10, 2015 09:29 PM
