Removing factory cd player from 2004 civic
Okay, I've searched foooooorrrrrrrrrever trying to find how to take the factory cd player out, and put in my new one.... Each one I find only gets me to the point of being able to reach up and touch the back of the cd player, but not one instructional web page has shown me how to get past that point... most sites just say, i was able to reach my hand up there and plug in the cord for my IPOD, but that's obviously not what i'm trying to do.... pleeeeeeeease, can someone help me
Re: Removing factory cd player from 2004 civic
Nevermind.... I just searched on this site, hah, shoulda done that first.... but yeah i found out i needed to undo those 2 screws.... gonna go try that...
If it has never been out it will be super tight to remove the first time. (then, each time you remove it you will hear a metallic tink sound as you loose the metal clips that BTW can NEVER be located)
Make sure you buy a harness for the new install. Don't cut factory plug.
Yeah, I finally got it out... It pissed me off pretty bad when i was taking the 2 screws out underneath the dash... you couldnt use anything but a wrench, which wasn't hard, but still i had to go search for my brothers wrench
but yeah, i finally got it out, and then i found out that the wires wouldn't fit my cd player, which is my old one... i'm gonna try to get a new one, which i'm about to make a topic about..... so yeah.... thanks tho... it was tough to take out the airconditioning/cd/yield thing.... i had to use a big putty knife and like stick it deep in there, and i was a little bit worried with how much pressure was being put into it to make it pop... but finally it did... so instead of putting it back on, for the time being i'm driving around with it loose until i can get a new cd player, or get the wire adapter thing....
blegh...
blegh...
hi Lesclaypool, can u give me the link of the site on how to remove an old cd player in Civic 2004. I have the same problem with my player, i want to replace it but i dont know how to remove it. Thanks
try doing a search. it's been DIY'd before. and welcome to the site. we're here to help, but don't expect to have everything handed to you. you need to put in some effort too.
I need to do the same on my 2002 civic.
pop off the lower panel with the 12v socket piece in it. it works to stick your finger in there and yank hard. it will pop off. then you can see the metal radio bracket above and remove two screws. once screws are off, yank hard and the whole upper console with radio will pop out. gently pull it out and unplug the 4 stock climate control connectors and hazard light connector, and radio/antenna connector. everything else just comes apart with screws from the back now.
CarStuff
Dec 6, 2020 12:52 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
SSMatey
Apr 13, 2015 06:09 PM
