Interested in PNP HID light kits on E-Bay... which ones??
Old Apr 17, 2007
  #61
Re: Interested in PNP HID light kits on E-Bay... which ones??
isnt that a glare shield so light doesnt bounce all over? i thought you needed that.
Old Apr 17, 2007
  #62
Intercooler's Avatar
Intercooler is an unknown quantity at this point
It is just removing the end. Probably 1/2" or so. The stock housing has a metal piece in it shaped the same way. Kind of redundant is the reason why maybe it makes a difference.
Old Apr 17, 2007
  #63
electric130's Avatar
yep, same thing i was thinking. if you didn't have the stock shield like we do, then you'd need it.
Old Apr 17, 2007
  #64
but it serves no purpose for light spread. it is only to cover the open tip of the bulb so people dont actually see the lit bulb and get blinded. actually since most h4 bulb have a coated front tip, we can take our shield off and it wouldnt affect anything. i tried it on an rsx headlight too that uses open ended h1 bulbs and i still didnt see a difference. the jdm civic lights actually dont even come with one.
Old Apr 18, 2007
  #65
interesting. don't know if it would help then.
Old Apr 18, 2007
  #66
If I am reading that right light still comes out the front. Does anyone know if our headlights are adjustable left to right? I can only find up and down! Any ideas on adjustment of this?
Old Apr 18, 2007
  #67
yes, there's an adjustment for up and down and one for left/right.
Old Apr 18, 2007
  #68
Any idea where on the left right? I found the up/down at the top on an angle that uses a hex key. I can't find anything for left/right? Can you give me a location or picture if you have it?
Old Apr 18, 2007
  #69
I found the DIY: https://www.civicforums.com/forums/7...k-warning.html
But it looks like a Coupe like I have you can't adjust L/R?
Old Apr 18, 2007
  #70
you can only adjust that on sedan, and there is a plastic cover over the gear you have to pry off. they say you cant technically adjust them left/right due to the nature of the reflector and light source.
Old Apr 19, 2007
  #71
couldn't you drill a hole in the brace like the sedan has on the coupe?
Old Apr 19, 2007
  #72
the coupe headlamp physically does not have a gear to adjust on the housing. sedan has one but its covered with plastic shield which can be removed with the headlamp off.
Old Apr 19, 2007
  #73
Any way to get the headlamp out without needing to take the entire front bumper off? That cover piece that is inside the housing.... How does it get removed? Do you have to seperate the two halves of the housing?
Old Apr 19, 2007
  #74
no its a cover on the outside over the gear. the headlamps dont have to come apart, they just need to come off the car. its near impossible to reach it with the headlight installed. this is assuming you have sedan lights. and bumper needs to come off to undo all the headlamp mounting bolts.
Old Apr 19, 2007
  #75
as gearbox said, bumper has to come off to remove the headlight housings. and if you're talking about the chrome shield inside the housings, yes, you have to separate the housings to remove that. i dont' recommend doing that though. with our crappy DOT regulations, i'd be willing to bet that the shield is helping the already bad output of the halogens. i don't know how it affects HID's. it may help, may not. i guess if you don't mind doing the work to remove the bumper, bake the headlights to separate them, remove the shield, re-seal the headlights, reinstall them and the bumper and check, then repeat the process if it's worse and you need to reinstall the shield, then go for it. seems like too much trouble for unknown results. i'd say cut the top of the HID shield off, if it doesn't help, JB Weld it back together.
Old Apr 21, 2007
  #76
I have messed with the adjustments enough to where I actually kind of like them and think I am staying with them. I am swapping them for a set of 4300K bulbs since I want a tad brighter and plan on taking the front part of the bulb shield off. Should be a go then!
Old Apr 22, 2007
  #77
that's cool. is the seller gonna let you swap them out or are you going to have to buy a new set?
Old Apr 22, 2007
  #78
He is just doing a swap for me.
Old Apr 22, 2007
  #79
that's awesome. glad this is working out for you. post some comparison pics of the 4300k's when you get them
Old May 17, 2007
  #80
hondaes1's Avatar
hondaes1 has disabled reputation
Hey did anyone here buy these for 04/05 Vic?
http://cgi.ebay.com/ebaymotors/ws/eB...m=320090442117
Just needed some help on installation, thanks in advance.
Old May 17, 2007
  #81
you can buy them from DONG here for $25 less. he's in the states too. so the kit doesn't come from hong kong.
Old May 18, 2007
  #82
hondaes1's Avatar
oops already got them, but i still need help installing, they are supposed to be plug and play but they aren't turning on and i'm a newb on this headlight stuff.
Old May 18, 2007
  #83
if you by chance hooked up one of the ballasts in reverse polarity, then you'll blow the fuse and neither set will work. other than that, 9006 set up is easy. it's not confusing like the H4 setups on the 01-03 civics.
Old May 21, 2007
  #84
hondaes1's Avatar
I may have to return them , becuase they aren't working.
Old May 22, 2007
  #85
did you try hooking the power and ground directly to the battery? try that and see if they work.
Old Aug 17, 2007
  #86
hondaes1's Avatar
Sorry for the late reply, but I finally got it to work. I was connecting the cable backwards to the ballast. nooooob...lolz... anyways they look hot.
Old Aug 17, 2007
  #87
i just bought the catz Zeta halogen bulb booster for my h4 setup. lets see how good it works.
voblak2
20
May 4, 2023 02:08 PM
CarStuff
Dec 6, 2020 12:52 PM
Rogelio Rey
May 24, 2015 08:30 PM
Paul Harsze
May 20, 2015 11:37 AM
WhosYoDadday85
Nov 11, 2001 05:41 PM
