Wire Connections?
Old Apr 30, 2006
05CoupeCivic's Avatar
05CoupeCivic is an unknown quantity at this point
Wire Connections?
Im looking at maknig the cleanest possible audio system so im trying to eliminate all of the weakpoints. Anyways how did you guys connect your wires behind your hu, in your doors etc... Did you just use the old twist/ ET way or is there wire connectors you can get? Ive tried butt connectors but the wires are too small for the ones i got..
Old Apr 30, 2006
DJayG's Avatar
DJayG is an unknown quantity at this point
PLEASE only solder. any connector you put on the wire will create a "weakpoint" or point of resistance which will drop voltage and decrease signal strength. See my thread on Amps for more description of loss of voltage
But please only soldered wires.
PS You cant spell Butt without Butt Connector
Old Apr 30, 2006
okay, thats pretty sweet considereing i just got a soldering gun.
How would i solder the wires? put a piece of wood under them and solder them together? You cant really solder in midair...
Old Apr 30, 2006
CraigW's Avatar
Solder yes, Use a "western union splice" and heat shrink where possible.
Old May 1, 2006
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
when soldering wire to the speaker terminals, dont get it too hot!! that can damage the voice coil.
Old May 1, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I've used crimped butt connections for most of the newer work I've done without incident - I've soldered in the past and you certainly can't go wrong with it.
Fastfebur
Apr 22, 2015 01:37 PM
Chuck94527
Jan 31, 2002 07:49 AM
HEBEGEBZ
Jan 24, 2002 03:01 PM
matt95401
Jan 21, 2002 11:50 AM
blackbullet
Dec 1, 2001 03:44 PM
