amp turns on but no sound!!! O_O
Old Apr 29, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
Exclamation amp turns on but no sound!!! O_O
hey guys. i just put in my old polk 12 inch in the back with a sony amp. everything was working fine until i just touched the amp as i was going to change the bass eq on the amp. by touch i mean so fragile a baby wouldnt even feel it. the amp powers on and everything. i tried rewiring the sub in different ways, tested it out with another speaker and still NO SOUND did my amp just conk out on me like that or is there an explanation? im pretty sure i cant kill my amp by just touching it because everyone touches their stuff. im so clueless, what could have caused this and how can i fix it?! thanks for any help in advanced, any help is appreciated
edit: i also checked my rca wires and rewired them to different channels of my headunit and stilll no go.
Old Apr 29, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
check your ground, then
check your amp settings (gain/level, bass boost, low pass filter, high pass filter, etc)
2nd, what amp and model sub is it? are you wiring the sub to an ohm load that your amp is capable of running?
Old Apr 29, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Check RCA cables as well
and did i read you have a Sony (Xploder?) amp?
Old Apr 29, 2006
yea i have a sony xplod amp. and isnt if that if it was a bad ground it wouldnt power on? im pretty sure its a good ground because i used the ground where a lot of other stuff is grounded at. i checked my rcas. i checked the gain level bass.... cmon lol i tried everything basic pretty much.
no help guys? i searched and couldnt find anything
Old Apr 29, 2006
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Sony Xplod <------- that's your problem.
Old Apr 30, 2006
that doesnt help me one bit. i just wanna get my amp working right now... nobody knows why its not working?
Old May 1, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
sounds like amp went bye byes.....
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
WLakers
May 4, 2015 06:23 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
May 1, 2015 09:37 AM
mohawkboom
Nov 2, 2001 06:00 PM
