where is the parking light output wire in the underdash?
Old Apr 20, 2006
WhiteRabbit's Avatar
Ive found it in the center console, Ive found the negative sense wire in the steering column, but I cant find it in the cluster**** of wiring above the fusepanel.
where is the 12V output parking light wire in the underdash?
Old Apr 20, 2006
um going to the blue cluster connector its the red/black wire...
Old Apr 20, 2006
is the blue connector above the fusebox, or in the kickpanel?
Old Apr 20, 2006
its plugged to the top of the gauge cluster. (above the fuse box). just gotta remove the bezel
Old Apr 20, 2006
welp, its certainly not above the fusebox, and I couldnt find a blue connector in the kick area (minus the cruise control molex)
what am I missing? is it BEHIND the fusebox? or on top?
ill give that a shot
Last edited by WhiteRabbit; Apr 20, 2006 at 01:00 AM. Reason: Automerged Doublepost
Old Apr 20, 2006
okay do you know what the gauge cluster is? the piece with the speedo, tach, gas, etc with needles. above the steering wheel. the blue connector is plugged into the cluster with a bunch of wires coming out.
Old Apr 20, 2006
which bezel?
I was checking for the gauge cluster wire harness hours ago this afternoon. I couldnt find it in the underdash.....
Last edited by WhiteRabbit; Apr 20, 2006 at 01:16 AM. Reason: Automerged Doublepost
Old Apr 20, 2006
you have to remove the black trim around the cluster to gain access to the wiring in back. there are two screws on top just below the dash that come off, then you need to stick your fingers in behind the bezel and pull hard. its glued on too so you need alot of force. once thats out, you can see where the cluster is screwed on, and where the connectors are.
Old Apr 20, 2006
I was wondering about that. the top pops right outl, but there was too much resistance on the bottom to just be some panel poppers back there. way too much.
Old Apr 20, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
going to the fusebox for the wiring is a pita. if you look at the green factory alarm plug up high in the drivers kickpanel you'll see a blue wire, thats the negative trigger for the parking light wire. Its actually easier to just take out the coin box unit and get the plug from there
Old Apr 20, 2006
yes, the neg wire is in the steering column as well, easy access. this alarm uses a high current +12V output, unfortunately. im stuck!
Old Apr 20, 2006
CraigW's Avatar
Have the output drive a small relay. Then switch the -trigger lead to ground.
Old Apr 20, 2006
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
What kind of alarm is it? because DEI alarms let you switch the polarity of the parking light output.
Old Apr 21, 2006
its an inexpensive remote start. I dont have that particular option.
Its all hooked up now. I appreciate the assistance.
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
klam
Nov 16, 2001 03:36 PM
wawacito
Nov 5, 2001 03:32 PM
NukeSilo
Nov 4, 2001 09:37 PM
