Grounding question
Grounding question
This link [Won't allow me to post link, so here it is 1. Check the ground, resand the surface and the actual terminal where you're connecting it. Use a screw designed for grounding (you can buy them at lowes/home depot, they're green). Drill a new ground as opposed to grounding under a bolt, check for gas tank clearance.] talks about removing alternator whine from you car. Number 1 on this list mentions drilling a new ground, I want to drill one somewhere under or behind the center console/radio/dash area. What will I need to watch out for when I do this? Thanks
just run the wire into the engine bay and use one of the factory grounds or make a new one. or even easier connect to the negative battery terminal.
no need to drill a new hole or buy special screws. i think for home wiring, green means ground and that is why grounding screws are green. they are no better for wiring, in fact they are worse if anything, because they are coated or painted or whatever.
moving the ground might get rid of your noise, but it is not a surefire way.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
sch2cm
Jul 21, 2015 09:58 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
