head unit wont turn on???
Old Jan 11, 2006
ripspecv's Avatar
ripspecv is an unknown quantity at this point
ok heres the deal. i wrecked my car about a month ago and when i was fixing it i replaced the whole front end. when i took it to my shop the head unit worked. then today i finally got done with it and the damn headunit or interior light wont work. what happen?? what can i look at to see if thats the problem? let me know asap im missing stern on sirius.
Old Jan 11, 2006
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
check your fusebox....I bet you blew a fuse
Old Jan 11, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
i heard stern this morning and he isnt that great...
but check those fuses and if there is an inline fuse on the radio check that also. Then check all of the wiring and make sure that nothing is loose
Old Jan 11, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
most likely domelight fuse
Old Jan 12, 2006
ripspecv's Avatar
ok this is gonna sound stupid but where is the fuse box located? i have my interior fiberglassed and i was looking last night for about 30 mins trying to find the fuse box inside the car and i can't find it. is it behind something i need to remove or what? im afraid they closed in the fuse box when they did the work.
Old Jan 12, 2006
coop's Avatar
pop your hood - look right next to the battery
Old Jan 12, 2006
the one inside your car is located to the right of the steering column, get down in the drivers footwell and look up, youll se a piece that you can remove with two fasters that you turn 90 degrees to release, after you remove that youll see it.
Old Jan 12, 2006
ripspecv's Avatar
no fuses are blowen. im so confussed.
Old Jan 12, 2006
does your dome light work?
Old Jan 13, 2006
ripspecv's Avatar
i fixed it. when i said no fuses were blowen i was wrong. i blew my backup fuse. i was like wat the h*ll. i just started pulling all my fuses and that was the one. who would have though.
Old Jan 13, 2006
coop's Avatar
common
Old Jan 13, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
i had that same problem with my head unit. Didn't even know the backup fuse had anything to do with the head unit coming on. Glad you got it fixed though.
Old Jan 15, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
yep,the backup fuse seems to be a common fuse blowing when u are playing around with anything in your car...
has happened many times to lots of members
Old Jan 17, 2006
TopFuel's Avatar
Ultimate OG Member
TopFuel will become famous soon enough
Glad you got it fixed...mine blows just randomly and I have no clue whats up with that.
Jeff
mugenca
Apr 16, 2015 12:15 AM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
ACEM2
Dec 22, 2001 09:14 PM
mwwhonda
Dec 5, 2001 10:52 AM
