Its that time again...post your systems...
Old May 5, 2009
  #211
fiend's Avatar
fiend is an unknown quantity at this point
Re: Its that time again...post your systems...
alot of these setups are nice, especially the one's where the whole trunk was overhauled for it, but i couldn't do that, i need my trunk space for groceries and what not...i just want something simple but something that looks good and leaves space, right now i have 2 tens in a double ported box (box was free) and an amp. i wanna redo it eventually but with one ten (maybe even a jl audio 8", if those are even still around lol) and an amp
Old May 5, 2009
  #212
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
JL is the way to go for limited space and for a fairly strong, clean thump. I used to have the w1 way back from when they first came out and even after several yrs, they still hit like they were brand new. I noticed a blown one but only when it was cranked, and the highs were turned off. I would recommend a small box with anything from w0, if they make them any more, up to a w3. Once I get the money, i'm replacing the Punch Stage 2's with the 12w3v3's
Old May 5, 2009
  #213
fiend's Avatar
i remember when the w1's came out, friend of mine had two 15's in the back of his explorer...with the volume quarter the way up it felt like my ribs were being crushed. i don't like alot of bass, i don't listen to rap, i listen to alot of metal so i'm thinkin a jl 8" would be sufficient enough, maybe with a 400-600 watt amp
Old May 5, 2009
  #214
Whatever kind of sub you end up getting, make sure you match the RMS of the sub to a correct amp. Most of the w0-w3's can only handle 250 watts. That is how my old ones blew, my cousin wired them to an amp that had higher output then what the subs were meant to be played out. Like I said though, they lasted a good 6 years and you still couldn't tell they were blown.
All i'm saying is to make sure you do your research first and why pay tons of money for a nice sub only to get a crappy amp? Go with a jl amp or similar name brand, i.e. alpine, polk, some of the higher ends.
Old May 6, 2009
  #215
fiend's Avatar
noted....thanks man
Old May 13, 2009
  #216
BlueEM2's Avatar
Whachya lookin at?
Alpine IVA-W203 head unit.
Clarion 640w max amp
2 crappy pioneer subs.
The subs and amp are old I took them out of my s10 when I sold it and decided to slap em into the car a week or so ago. Sounds okay, I don't mind the stock speakers all that much, I just can't turn it up too loud haha.
Old May 13, 2009
  #217
KcRidin09's Avatar
KcRidin09 is an unknown quantity at this point
I guess Ill add mine to the list.
I have a Kenwood KDC MP638U headunit
replaced all factory speakers w Alpine composits
1 JL Audio 15w3D4 sub
Hifonics TXi7508 mono block amp.
in the pics I have the amp mounted to the floor board. it is now mounted on the back seat with all wires still tucked. Thnx for lookin
http://viewmorepics.myspace.com/inde...218&i=34690728
http://viewmorepics.myspace.com/inde...218&i=34690722
http://viewmorepics.myspace.com/inde...218&i=34690717
http://viewmorepics.myspace.com/inde...218&i=34690710
Old May 13, 2009
  #218
Stearic's Avatar
Stearic is an unknown quantity at this point
Originally Posted by Silvership05
I could be wrong but I think that 01-03 only has 2 but 04-05 have 3. my 05, girlfriends 04 has 3 but my 01 only had 2 if i recall.
I have an 04 and i only have the 2 tabs there. Maybe it's a difference in the trim level of the car? What is here 04? Mines and LX.
Old May 14, 2009
  #219
povar's Avatar
povar is an unknown quantity at this point
- Pioneer AVIC-N2 with CD-VC1 Voice Command
- (1) Load Boss 170 amp H.O. alternator
- (1) Optima Yellow top
- (4) BatCap 800
- (2) KS40 / (4) KS525/ (2) KS65/ (2) KS693 coaxials
- (1) RS65.2 component set
- (2) KX650.4
- (2) KX1200.1 (Stillwater Designs modded, 1610 watts each)
- (4) S12L7s (waiting on the '06s... almost here :-D)
- (1) KQ30 30 band equalizer
- Stinger hardware (cables, fuses, distro blocks, voltage meters, etc.)
- Second Skin "Damplifier Pro" sound deadening
- custom mounted remote gain controls and switches (each amp is given an independent remote lead from one of a pair of relays, as are each set of L.E.D.s)
- L.E.D.s in vents, neon tube under rear deck lid
more at tireunit.com
Old May 14, 2009
  #220
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
Kenwood X789 MP3/CD/HD Headunit
All factory speakers are now Polk db components in front and 3 ways in back
2 - MTX Blue Thunder eXtreme 10" woofers
MTX Thunder Pro 400x5 1600Wx5 (400x4 @ 2Ohms, Mono Block 385Wx2 @ 2ohms)
Rockford Fosgate .5 Farad Capacitor
Dynamat'd the whole trunk, rear deck and doors
All cables are monster cable gold plated *BLING YO*
Braile Lightweight battery (which is why i need the capacitor)
Old May 15, 2009
  #221
Silvership05's Avatar
Silvership05 is an unknown quantity at this point
are you saying they blew after 6 years or were blown the whole time??? that statement confuses me. if the subs were blown youd notice because.... well.... they wouldnt work lol
Old May 15, 2009
  #222
What I mean by blown is that they distort. I could only tell they distorted when i disabled my highs and mids and only played my bass at max. The subs are still bumping to this day and I would put them back in my car, but the cosmetics aren't looking too good on the subs. The ring is slowly falling apart since it was made out of a paper material. Anyway, they aren't blown, just distorted slightly, and would give any average joe that thump that he/she needed
Old May 16, 2009
  #223
i gotta say ive never heard of subs being "partially" blown before. are you sure you arent the cause for the distortion? eq too high, bass boost maxed out, or gains set way too high, wrong crossover settings?
only thing i can think of would be a voice coil scratching but the sub wouldnt last long after that, if that were happening.
Old Jun 4, 2009
  #224
WhiteRabbit's Avatar
here's a de-install to mull over, to give you guys ideas.
http://www.diymobileaudio.com/forum/...s-install.html
5 CD changers, super nintendo w/7" TVscreen, 4 amplifiers @ 65x12, 350x1, (run at 165x6, 240x1), 12 channels of signal processing, 13 batteries (equivalent to several yellowtops), advanced key (w/ keyless ignition), and more wiring than anyone should ever choose to deal with in one car.
Hope you guys are still enjoying your hondas.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
