Which set-up would you prefer?
Old Nov 25, 2005
Trustfall990's Avatar
Trustfall990 is an unknown quantity at this point
I plan on getting component 6.5's and a pair of 6x9's im deciding between Infinity or Alpine. For the moment they will be run from the HU untill i can get a 4ch amp but that won't be for at least another month. Thanks
Old Nov 25, 2005
southpasdena's Avatar
Super Member
southpasdena is an unknown quantity at this point
depends which models you are comparing. The infinity perfects component set is a little brighter than the type x and put out a little less bass in my opinion, otherwise i think the type r comps will sound better than the infinity kappa's. 6x9 i have no clue since i never planned on running those
Old Nov 25, 2005
Super Member
go to a good guys if you have one around, i know they always have carried the bottom to top for comps from both those companies, so then you can listen, but dont buy from them, they arent authorized dealers
Old Nov 25, 2005
ajhdragon's Avatar
7thgens official a$$hole
I would personally get the infinities, and then get maybe something like a rockford P2 or kicker comp VR to give good clean bass with it.
Old Nov 25, 2005
MegaHurtz's Avatar
They are both good speakers, it's all a matter of opinion.
Old Nov 25, 2005
Super Member
you might want to add eclipse with these, i think they are around the same quality and price
Old Nov 25, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
personally, i've always like infinity, they can take way more of a beating....i first got my kappas when knew slim to nothing about car audio. long sotry short, a had a cap explode and take out my amp and 6x9s.....but the kappas survived and sound the exact same, my buddy HAD some type R component and they blew from him setting the crossover wrong. plus, I've hear both and i liked the infinity's sound better, cleaner, more defined.
Old Nov 25, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
if you're going for the new infinity kappas, make sure your amp can handle 2ohms cuz that's what they are...i dont think decks willl like seeing 2ohms hooked up to them...
on a side note, i've hooked up a 2ohm load to an alpine vdrive deck and cranked it...deck didn't complain but i have no idea how long it will last in the long term..i dont think decks are made to handle 2ohms...
Old Dec 2, 2005
yourpalmike's Avatar
yourpalmike is an unknown quantity at this point
i like infinity.
6000cs front
6002i back.
awesome quality.
Old Dec 17, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
consider the polk db serie's or momo serie's
Old Dec 17, 2005
jttegx's Avatar
OMNES AD UNUM
the alpine type-r series sound like ***. this comming from an hip-hop/trance person.
polk db's are great speakers but lack midbass range.
rockford's punch 6.5" components would probably be a good consideration if your just running thru deck power.
infinity's...never heard their components before.
dont spend too much on the 6x9's...its just a rear fill. just get some decent 2ways or 3ways and be done with it. but make sure you get a nice set of 6.5" components on the doors.
Old Dec 17, 2005
booba5185's Avatar
i agree 100% except i have heard infinity, sounds GREAT for mid's an highs, a little lacking in the mid-bass, but sound good 6x9s cover that up. I actually have Infinity Kappa 6.5s in my vic and love every second of them, best mod i ever did to my stereo excpet my sub.
Old Dec 17, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
read mt sig...
Old Dec 18, 2005
synod's Avatar
synod is an unknown quantity at this point
Hey, I have an alpine cde 9845 that puts out 16W RMS x4, and I found that these kappas have a 75 watt @ 2 ohm RMS, would that mean that the deck would effectively be putting out 64 watts @ 2 ohms? Or is there some kind of procedure I'd have to do for it to actually be doing that?
Old Dec 19, 2005
LowSky's Avatar
HU's cannnot, repeat cannot deliver a steady 2 Ohm load and should not be used to power 2 ohm speakers
Sep 26, 2023 06:44 PM
BootyDo
Jun 21, 2016 03:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
curaze
Sep 22, 2015 08:27 AM
scotchtape
Sep 18, 2015 04:15 PM
