Sub flickers in and out: PLZ HELP!!
Old Dec 15, 2005
JOO's Avatar
JOO
JOO is an unknown quantity at this point
sup guys. I have never had this problem before but my sub flickers in and out of songs now. Sometimes the bass is on, and then it just completely shuts off. I checked out all the wiring in my trunk, which includes the box, the sub and the amp. I also noticed that my car is giving off alot of electric shocks now when I get out of the car. I dont think it has to do with any wiring in the back of my trunk, i think it might be the head unit?? the flickering if getting less and less and I havent heard my sub for a couple days now. i dunno wats wrong.. plz help if you know whats up.
-thanks
Old Dec 15, 2005
eye_see_you's Avatar
let the devil out
besides shock is normal when its colder it sounds like your amp may be over heating possibly to a bad voice coil.
Old Dec 15, 2005
7thGenerasianCivic's Avatar
I also have the same problem with my 15" Kicker. When I push the speaker back, then it bumps (or lay it facing up)...
Old Dec 15, 2005
WKHCivic's Avatar
WKHCivic will become famous soon enoughWKHCivic will become famous soon enough
Mine did that too, but it was an easy fix. I checked my wiring and the ground on the amp kept comin lose so when it would lose its ground it would shut off and when it would touch again it would come back on. So, I know you said you checked the wiring but just try and ground it somewhere else. Let us know how that works.
Old Dec 15, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
as they said, when you push on the sub, if it starts bassing again, it might be your voice coil that is f**ked. Take it out of the box, remove the wires on the sub, now put a ohmmeter on the terminals, it should read close to what your subs ohms rating, if it reads more resistance than what your sub is supposed to be or it says OL (overload) it is your voice coil, now try pushing on the sub and look on the ohmmeter, if it starts to read something different, that's your problem. I've seen that happen alot. it might also be the wires going from the terminals to the sub (tinsel wire), check those also.
Old Dec 19, 2005
so is a bad voice coil fixable? Any ideas?
Old Dec 19, 2005
05reverb's Avatar
usually not, only more expensive subs are repairable. some kickers can be fixed but not sure what model.
robjcivic
Mar 12, 2017 12:10 PM
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
mac25
Aug 21, 2015 11:14 PM
jody501
Jul 10, 2015 11:01 AM
