Help! Infinity Kappa 62.5i 2way on 2004 Sedan
Old Mar 9, 2005
Pitch_BlacK's Avatar
Pitch_BlacK is an unknown quantity at this point
Hey guys I want to ask if Infinity Kappa 62.5i 2way speakers will fit perfectly on a 2004 sedan? I want to upgrade all my speakers front and rear.
I wish civic sedans have 6x9 instead of 6 1/2 at the back.
Old Mar 9, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
What do you mean by perfectly? That's a tight one, It might fit it might not, search the forum. It's within 1/8" of the mount depth of the door. Either way, worst case scenario is you use an mdf spacer which you can either buy or cut yourself.
Why do you wan't 6x9s instead of 6.5? Are you looking for bass without subs?
Old Mar 9, 2005
ferio's Avatar
ferio is an unknown quantity at this point
it would fit. mine did
Old Mar 10, 2005
I'm not really thinking of putting subs in my car. I just want some clean and clear sound with a lil bit of bass on it. That's why I wish sedans have 6x9 rear speakers.
Some cars have very loud subs that you can't even hear the vocals anymore.
Old Mar 10, 2005
Yo man, Do you have Kappa 62.5i speakers all around? Did you had problems with removing the door panels?
Old Mar 10, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
6x9's aren't a whole lot better at reproducing bass. BTW Infinity's are much better at producing high frequencies than they are at doing bass... I've got the kappa's up front and the bass is pretty anemic for an aftermarket speaker.
Old Mar 10, 2005
ferio's Avatar
i have infinity speakers all around. i think i have the 605cs(i forgot the exact code but it came with tweeters and xovers) and 652i's at the back. removing the door panels were easy. it just takes time
Old Mar 10, 2005
Do you have power windows? If you do I was wondering on how you removed the panel with the power window switch.
Old Mar 10, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
NO 6.5" will not match up with w/ the stock holes....u WILL HAVE to drill new ones.
and that will be a bitch....cuz of the small angle
Old Mar 10, 2005
ASWZero's Avatar
ASWZero is an unknown quantity at this point
scosche makes an adapter for the 6.5 for the rear 6x9 speakers. I have a set sitting in my garage awaiting speakers. personally, round speakers sound better. i have sony ES 6x9 in my rear right now and my 6.5 sony ES components in the front provide better bass.
Old Mar 10, 2005
J187's Avatar
That is not true.
Yeah, that's what I was getting at when I asked if you were going to have subs. I was going to tell you if you were gonna get infinity all around, You'll have a pretty high-end system. High end of freq response that is. They don't do well with lower freq.
Also, If you want a little bass without subs, I believe WhiteRabbit has had good luck using Tangbands but I'm sure the mounting depth would be an issue with the trunk spring rods, you may have to revert to a strut system.
Old Mar 10, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
I think he is talking about the rear, so yes there are some that matchup. If he was talking about the front, you would be correct.
Old Mar 10, 2005
J187's Avatar
Front or rear, there are speakers you can use without having to "drill new holes"
Old Mar 10, 2005
diskreet's Avatar
reference series = excellent bass/mid
kappa/perfect series = excellent mid/high.
also a 6.5" speaker can make more bass and cleaner than a 6x9 if it was built better!
Old Mar 10, 2005
are on crack? i have installed both front and rear.
for the front u have to use the spacers.
and for the rear...i believe only 1hole matches up(not very stable)....so u have to drill 2 new holes to line up w/ the 2 on the speaker
Old Mar 10, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i dont know about the sedan but on the coupe, you can install new 6x9's into the stock location without drilling or using a spacer...
however, trunk springs will be a problem for speakers w/ big magnets
as for fronts, it's almost definite that a spacer is needed. you can get away with not drilling new holes if you make the spacer wide enough to mount where the holes are for the stock speaker. that's what i did but the spacer had to be cut to shape perfectly.. the spacers will get in the way of the door panel if spacers are too wide.
Old Mar 10, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
found these on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...category=38646
great for the front doors
Old Mar 10, 2005
J187's Avatar
No I am not on crack. I am the one who is correct in this argument. I am not saying that there are lots of options, I'm just saying that there are speakers you could install in either location without having to use spacers or drill holes. For instance, Infinity Reference series, shallow mount 6.5" REF6002SI, LESS THAN A 2" MOUNT DEPTH!! They go right in, I saw it done recently. I personally would have made baffles for the speakers, but I wasn't doing the install. Power akoustic, Rockford, Pioneer, JBL - they all have speakers with less than a 2" MD. Also, a while back we put, I think it was boston pro series 3-way 6x9s in a civic. The magnets didn't fit with the trunk springs but the speakers lined right up.
Old Mar 10, 2005
Ok guys I'm convinced that round speakers are better than 6x9's. Thanks for the comments on installing these type of speakers. Appreciated!
So I will need spacers for the two front speakers. (Front speakers solved)
Is there anyone who has a "SEDAN" that has 62.5i kappa rear speakers? If there's someone I'd like to ask if you had any problems installing them?
Old Mar 10, 2005
4Saris's Avatar
Fill me in J, what kind fit in the front with no drilling?
Old Mar 10, 2005
turboslug's Avatar
Super Hoser
on the coupe doors (and prolly the same with sedans but i'm not 100% sure since i dont have a sedan), the speaker holes are not circles and there aren't any stock screw holes. stock door speakers mount onto the door using 3 clips.
on the door, mounting depth isn't the biggest problem. it's the width of the hole in the door. most speakers require a spacer because the hole is so small that the speaker basket wont go through the hole(unless you cut the hole bigger).
i installed alpine type r 5.25" components because i didnt want to cut the hole bigger. even though the speakers were 5.25", they still barely squeezed into the stock hole(very tight fit). i still had to use a 0.75" MDF spacer just to get the basket to clear the sheetmetal. i also had to cut a little tab off of the basket to make them go through the stock hole.
i heard that alpine type s components come with the spacer required to install the speakers into 7th gen civics. you still have to drill holes in the door.
Old Mar 11, 2005
J187's Avatar
Kappa shallow mounts. Take em' out of the box, put wires to them, put em' in the door holes and screw em' in. Done. Dont' drill anything. More importantly, no need for spacers.
What you guys need to realize is, you are splitting hairs. I didnt' say that there are tons of speakers that snap in like Fking legos! I said you don't always need to cut the metal, use a space and drill holes. Simple statement and It is correct. I'm not saying its good, better, best, sensible, stupid, or anything like that. I'm saying it is POSSIBLE. And, IT IS. Do most speakers require spacers? YES. Do lots require you to cut the doors? YES. But some dont'
This implies that the speaker holes will not be suffice for any speakers. I simply said, that some speakers will fit in the holes. That is all I am saying.
What "Small angle" are we talking about? Does he mean the rear deck? Because the previous posts before were talking about the doors, then came the one I quoted above, I can only assume we are still talking about the 6.5" in the doors . . ?
Old Mar 11, 2005
J187's Avatar
Pitch, if you are concerned for bass, even a little bit, I wouldn't go for the infinitys as they are notorious for not playing low. You could look into some 6.5" subwoofers like Jl w0s or Kickers, see how they might fit. PUtting an amp to em' would give some pretty good bass for not having subs
Old Mar 12, 2005
I'll check out some JL speakers I heard that their good too. Thanks
Old Mar 12, 2005
J187's Avatar
Yeah, they do a pretty good job of providing bass for such a small cone. But, I haven't used em' in a while and don't remember what they are like size wise. Probably pretty big whereas they are a subwwofer.
Old Mar 13, 2005
ferio's Avatar
yes, i have an EX. there is just a clip holding the harnes from the power window switch. just pull(not too hard) the clip. it'll come off
tomas6791
Aug 22, 2015 12:20 PM
18
Aug 17, 2015 08:02 AM
Aug 13, 2015 03:44 PM
justcruzin125
Aug 11, 2015 09:09 PM
General 7th Gen
Jul 9, 2015 10:17 PM
