opinions please... speakers for my civic
Old Feb 23, 2005
  #31
Do we have to buy a lamp to get the wire? I see what you mean tho. I never thought speaker wire was shielded, only rcas.
Old Feb 23, 2005
  #32
PopcornPlaya's Avatar
Electric Boogaloo...
I never said to buy overpriced speaker wire. I said to make sure it's well insulated. Wire is wire, just make sure of the quality before you buy it, no matter the price. See, you're inferring things that I didn't say. I never said to go out and buy the most expensive wire, because yes, it is a marketing ploy. I just said to make sure it's quality made. Big difference.
Old Feb 23, 2005
  #33
Mystic3030's Avatar
Yup, i'm an A$$hole.
Bires, technically thats not the best speaker wire for all applications.
I run 250 watts to each of my front doors, I use 12 guage twisted oxygen free copper wire. I never get any interference from my windows or power lock motors, and my wire runs through the grommet that my main harness goes through.
Another thing to consider is strand count, as different wires for different applications have different counts. The higher the strand count the more flexible and the more efficient the wire will be. Power travels along the outer surfaces of the wires.
Also, your lamp cord isnt marked for + and - which can make running 20 feet of wire from the trunk into your doors and then wiring it REAL fun.
Old Feb 23, 2005
  #34
Mystic3030's Avatar
You can buy it at Home Depot on spools or by the foot should you chose to use it. Be warned that most of it is not marked for polarity so it's a pain to use for wiring.
Old Feb 23, 2005
  #35
Hmm well I went out and bought some regular copper wire from autozone. Is that good or will I not even notice a difference. How can you tell what the speaker polarity is because it's not on the speaker.
Old Feb 23, 2005
  #36
The larger spade/connection will be positive.
Old Feb 23, 2005
  #37
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
Running the wiring thru the door is hard. Took me couple of hours. It took me so long because it was my first time And second reason was I didnt want to cut any of the wiring that come to the door(power windows and etc). Now i think about it couple months down the road, it was well worth.
Old Feb 23, 2005
  #38
You didn't use silicone spray did you?
Old Feb 23, 2005
  #39
Bires's Avatar
Bires is an unknown quantity at this point
That's what I have done in the past. Industrial-grade wiring is sometimes color coded though for polarity. Most recently, I got some great 14g lamp cord where one wire's insulation was square, while the other's was round.
Old Feb 23, 2005
  #40
Bires's Avatar
All good points. I aggree with you. If you run 250W max to your doors, a good twisted line would be best. My point earlier was that most ppl don't, and most commercial speaker wire is not neccessary/better than cheaper, more creative solutions.
Old Feb 23, 2005
  #41
would this make a difference if I'm only running 40wrms to each speaker??
Old Feb 23, 2005
  #42
Bires's Avatar
nope. The 18 g wire in the harness only travels about 3ft from the center console to the speaker, well within tolerances.
hernandexz
Oct 28, 2021 10:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
McD
Apr 29, 2015 03:50 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
inarschenk
South
Apr 18, 2015 04:29 PM
