How to make Head lights come on automatically
Old Dec 30, 2004
P64's Avatar
P64
P64 is an unknown quantity at this point
I have a 5-door Hb civic (european) and was wondering if it is possible to wire your head lights to come on with a turn of a key?
Thanks for assistance, A
Old Dec 30, 2004
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
yeah you can, what yr? trim model?
Old Dec 30, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
From the auction description:
For added safety, Lights On! can also be installed so your cars headlights will turn on whenever the engine or the windshield wipers are turned on.
Old Dec 30, 2004
P64's Avatar
P64
2003 1.6 ES VTEC II (D16V1 engine). Interior is similar to this:
http://www.avto.net/tr/2035397_18_11...r-8100949p.jpg
The main reason for this is that it is impossible to see in daylight if any of the three buttons are on (air circulation, A/C, window heating), since it is obligatory in our country to have the headlights on day and night.
And not to forget them
I was thinking if there is some relay I can stick in or something not requiring too much interfeering with wires.
Thanks so far, A
Old Dec 30, 2004
streetglower's Avatar
how is it impossible to see in the daytime?
Old Dec 30, 2004
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
I am wondering how hard it is to wire it?
Old Dec 30, 2004
ImPulse's Avatar
"Simple Installation.. Designed so that installation can be performed with simple household tools. Easy installation connectors are provided"
seems easy too me
Old Dec 30, 2004
tbaleno's Avatar
I may actualy get the kit and try it out..
Old Dec 31, 2004
profuse007's Avatar
Senior Member
| HEADLIGHTS|blue/red |- |headlight switch |
use a relay, SPDT or SPST is fine... wire in this fashion:
85-ground
86-| IGNITION|black/yellow |+ |ignition harness| (fused)
30-ground
87-head light wire (diagrm shown above)
Old Jan 1, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
why do your head lights need to be on with your windshield wipers? I noticed signs like this as I was driving through new york state
Old Jan 1, 2005
tbaleno's Avatar
because in theory its gets darker when it rains. So in their ultimate wisdom they made a law that says since it gets darker when it rains and you use your wipers when it rains you must turn on your headlights if you are using your wipers. Also I think it helps you see on comping cars through the rain if they have their lights on..
Old Jan 1, 2005
shmik1's Avatar
^^^ its law now... wipers on...headlights must be on
EDIT: summary of wut he said
Old Jan 3, 2005
P64's Avatar
P64
OK.
I thought this over and this is what I want to do.
Result will be: key turned to contact, engine oil light out - headlights on. With a twist of a headlight switch to position lights - headlights off. Headlight switch on - headlights on.
I will have a friend making the circuit to deal with so many inputs to control the relay for lights.
There is just one thing. Do I have to tap the engine oil light at the cluster or is there the easier way to do it?
Thank you, nice day, A
Old Jan 3, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Hm - I wouldn't mess with a light dependent on a sensor like that. Perhaps instead of tapping the engine oil light, you could tap into the parking brake, like how people with LCD's in their cars are supposed to that way you can't watch video unless the pbrake is on. I figure it's a ground, right? So then you just need a 12v to switch the relay, then 12v fused power from the battery to the headlights.
hokiedad4
Apr 30, 2015 07:18 AM
SpeedRacer
Nov 13, 2001 02:19 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
cazminn
Nov 9, 2001 11:18 AM
sonsonzai
Nov 4, 2001 12:52 PM
