ground wire
Old Jun 21, 2004
nickm748's Avatar
ground wire
(i seached, and didnt find my answer) hey guys, im running two jl amps from my trunk. One is a 300/4 and a 500/1 and I was wondering where is a good sonild ground mounting place.
Did the factory put one any were where you can put the ground in the trunk
thanks
Old Jun 21, 2004
I put both my amp grounds to a hole in the metal hump between the trunk and seats. Just find a screw that will be tight. I can take a pic if you want.
Old Jun 21, 2004
Project2k2's Avatar
If u lift up your carpet, right infront of your back seat (that's confusing) in the trunk, there are a few bolts that screw down into the trunk....use those.
Old Jun 21, 2004
doubledeuce2k2's Avatar
or if you lift up the rear seat you will find a bolt that the seatbelt uses, also a great easy choice for grounding
Old Jun 21, 2004
Yeah those are good. Mine's just a tiny screw holding it. Just be sure to shave off the paint and put connector protector grease (dielectric) so it doesn't rust up.
Old Jun 21, 2004
as long as it's a good connection (clean) and it doesn't pop loose, you're money. so don't duct tape onto the trunk lid please...
Old Jun 21, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I highly recommend a wire wheel attachment on a dremel - small enough to get to those hard to reach places.
Old Jun 22, 2004
nickm748's Avatar
nice guys
thanks
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
