Fiberglass Enclosure
Old May 10, 2004
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
Question Fiberglass Enclosure
Does anyone here have a fiberglass enclosure (painted, not carpet)? I'm planning on doing one just want to get some ideas on what design I want. If you have a custom fiberglass painted enclosure please post pics...thanx!
Old May 10, 2004
tfnaaf's Avatar
BLDNPSI Mod
Its not painted its sprayed with bed liner material. But i could have painted it i had it smooth enough to, just thought for duarbility the bed liner material would be better. It dont scratch real easy
Old May 10, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
FIBER GLASS WITH CF OVERLAY...SORRY ITS A NIGHT PIC...BUT YOU GET THE IDEA..
Old May 10, 2004
Ed's Avatar
Ed
Hey, tfnaaf, do you remember how much airspace you got in that enclosure?
Old May 10, 2004
KaZeLL's Avatar
I BUILT IT SOME TIME BACK, I CANT REMEBER OFF THE TOP OF MY HEAD, BUT I DO REMEBER IT WAS ALOT MORE THEN WHAT WAS NEED FOR THE SUB...I BELIVE THE BAZOOKA T2 ONLY REQ 1.2 QAV PER SUB I WAS LIKE AT ALMOST 2 PER SUB, THE END RESULT WAS A LOWER BASS WAVE...REALLY NICE FOR THAT GETTO LOW BUMPING...LOL
Old May 10, 2004
Ed's Avatar
Ed
I was wanting to make an enclosure for the side of the trunk for a shiva, I want about 1.8 ft^3 sealed, do you think that'd doable for the right or left side wheel well?
Old May 10, 2004
tfnaaf's Avatar
BLDNPSI Mod
to tell the truth i have no idea of the airspace, but i would guess its somewhere around 1.5 to 2 cube
Old May 11, 2004
Ed's Avatar
Ed
oh, one other thing, what size is that sub?
Old May 11, 2004
tfnaaf's Avatar
BLDNPSI Mod
mine? It's a DVC 15" Power Acoustik
Old May 11, 2004
Ed's Avatar
Ed
yeah, your. Thanks a whole lot My Shiva should be significantly smaller than that beast I'll have to give the fiberglass thing a go. Any advice? I've fiberglassed before, but nothing like that. I saw your other pics in yoru allery, looks nice
Old May 11, 2004
Rufus's Avatar
Fiberglassed into spare tire well. 4.1 Cubic feet, 2 Dianmond Audio TDX104's tuned to 35Hz with slot ports.
Old May 12, 2004
WhiteRabbit's Avatar
man, i never miss a chance to show this one off:
its only primered, not painted, but the primer matches the color so well, my guy doesnt think he even wants to paintmatch it to the car!
Old May 12, 2004
tfnaaf's Avatar
BLDNPSI Mod
I've used masking tape on all my fiberglass projects on the back side so the fiberglass releases. I think they make a product thats specficaly for mold release, but masking tape has always worked for me. Use LOTS and cover more of the area than you think you will need to to make sure you dont get any on carpet/stuff ( if your making kick pannels ). When i make mine i use hot glue gun to build the skeletal frame, and hold the woofer ring in place. After the back mold is all made and the frame work is done ive used a varriety of products to wrap the front of the enclosers like speaker grill cloth, polar fleece,hell, just about any type of fabric i could find. I then use hot glue or stapples to hold the fabric to in place on the back after its wraped. Do a couple layers of Glass, deppending on how thick you need it to be, then finish with bondo or similar product to get the finnal shape that you are wanting. Then finish with paint, vinyl, paint ...whatever! Ive seemed to have lost my pictures of my last few systems ive made had them all saved on a disc and cant find it for the life of me Most showed step by step how-to.
Old May 13, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
can an ENTIRE ONE PEICE floor board fit into the trunk? like is it easy to get in and out? i did a new floor, but its split down the middle.
Old May 14, 2004
nono, the way to go is to split it into three pieces. That way, you dont have a large seam right in the middle to be an eye sore.
the middle piece extends as wide as possible in either direction but still retains flat sides. then you make two pieces to finish the sides, lay them next to each other, and carpet over it.
the carpet becomes the hinge!
then you can fold hte sides up, insert it into the trunk, then fold them down into place
i fyou look real careful at the WRX pic above, you can see the seams
Old May 18, 2004
2k1civic.com O. G.
good idea! thanks )
Old May 19, 2004
bzrollin's Avatar
bzrollin is an unknown quantity at this point
here's a pic of mine:
http://www.7thgencivic.com/memberrid...php/photo/4376
Old Jun 5, 2004
that's pretty tite
General DIY
Sep 25, 2015 08:02 PM
djdefcon
17
Apr 6, 2005 11:52 PM
Bryn
Apr 27, 2002 05:08 PM
01EXtc
Apr 11, 2002 12:52 PM
Grey
Jan 25, 2002 03:14 AM
