front speakers
Old Mar 17, 2004
rinsincivic's Avatar
rinsincivic is an unknown quantity at this point
front speakers
to all that have systems
how did you change the front speakers in your 7th gen with the shape
of the hole in the door being a wierd shape?
just curious to see how poeple did it
laters
Old Mar 17, 2004
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
I made an MDF ring and screwed that onto the door... then screwed the speaker to the mdf ring... or you can bypass all that trouble because somebody either metra or scoche makes a speaker kit for the civic...
Old Mar 17, 2004
tom1178's Avatar
tom1178 is an unknown quantity at this point
i fit mb quart 6.5's in my car by bringing it to a local hole in the wall startup shop owned and operated by a kicka$$ 9 yr installer who had just opened his own shop, he used an air compressor with some type of saw blade to cut through the metal of the door to fit my speakers, he made baffles using MBF to mount the speakers and then to the door, I watched as he did it, took about 3 hours, he charged me $60 and gave me a verbal agreement to a lifetime warranty on the install, i'm sure nothing will ever happen to the install, he just wants to let people know that if there's anything wrong with the work he does he'll fix it and make it right.
Before going to him i went to 2 other places to get the speakers installed....first was a place called Tweeters, the installer told me to come back in a few months because he was too booked to install speakers i bought elsewhere, the 2nd place was a place called boomer mcloud's (i call them Booming McClowns) who said oh no, you can't install 6.5's in your civic, they must be 5.25's, i have a bunch i could sell to you and only charge you..lets say $50 for the install, $75 if they are components.
There are several ways to install your front speakers, easiest is with a baffle, if you need to cut into the door this can be done (i've heard) with aviation shears, another technique somebody mention recently (i think it was whiterabbit) is to cut outward with a saw or whatever you have straighlines outward from where the center of your speaker would be, kind of like sun rays or something, then hammer the metal back and out of the way..making room for your speakers. Sorry for the long post, slightly off topic maybe, i think i have a drinking problem.
Old Mar 17, 2004
vietfob714's Avatar
I dont think mine was that complicated... took me an hour and like $5 worth of wood and a jig saw... not even $5 cuz the rest i ended up throwing away... but it works fine, sounds great, no rattle or anything. i got pioneer 6.5 4 ways in the front.
Old Mar 17, 2004
LiKEaFeRiO's Avatar
I used universal 6.5" plastic spacers from Frys to fit some Infinity components.
I still haven't done my passenger side so I'll try to take some pics tomorrow and put them up as a DIY.
I did my drivers side 4-5 months ago =)
Old Mar 17, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
I had baffles custom made because depth from my boston 6.5's is too deep. the speaker hole was enlarged slightly to accomodate, however the installer left everything intact so that I could convert back to stock if I had too.
Old Mar 17, 2004
dma001's Avatar
dma001 is an unknown quantity at this point
I used pre-made spacers (Scosche) that I bought from SoundDomain.com. Worked like a champ...you just have to make sure the speaker is "centered" in the opening. I drew a circle around the stock speaker with a sharpie before I removed it; that gave me an idea of where the new speaker's center should be.
Old Mar 29, 2004
tom1178's Avatar
It all depends on the mounting depth of your speaker and the size of the speaker, not all 6.5's are the same (depth and basket size)......the scosche adaptor for example works for "most" applications.
Old Mar 30, 2004
MagMetal04
Guest
Posts: n/a
we also cut the metal of the door to more of a circular shape.
Old Apr 18, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
ok, i would like to install alpine SPR-174A speakers
http://iweb.alpine-usa.com/pls/admn/...y=90&p_main=10
how thick of a spacer(baffle) will i need? is 1/2" enough or do i need 3/4"MDF?
also, do i need to hack away at the sheetmetal to in order to get the magnet inside the door? how about the plastic part of the door? do i need to cut away any part of the plastic door panel?
BTW, will installing new front speakers give me more bass? i already know it'll give me much better highs but i would also like a little more bass. right now i dont want a sub in the trunk and my rear MTX 3way 6x9's are actually giving me less bass than the stock speakers. (it would be great if someone can reccomend me a new pair of 2way 6x9's(i dont want components because of the trunk spring issue)
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
General 7th Gen
Jul 9, 2015 10:17 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
