Wiring sub question...
Old Jul 31, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I am soon going to put my sub-amp under the passenger seat (since the 4 gauge wiring is already there from my ill-fated attempt at my 4 channel amp under there (which is going to be relocated to the trunk). My question is: Will there be a problem with this setup under the seat since the speaker wire (16 gauge) will have to run all the way from the passenger seat to under the trunk? Will there be a problem of the signal/power traveling long distance?
Old Jul 31, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Nope....although for subs I usually run 12 guage wire.....
Old Aug 1, 2003
MangoEX's Avatar
Just Be
My sub will be 360 W rms.. is 16 gauge enough Mystic?
Old Aug 1, 2003
MangoEX's Avatar
Just Be
Im getting the JBL 180.2. does 360 w x 1 rms bridged. what sub do you reccomend for this? Anything for around 150?
Old Aug 1, 2003
LudlamTheory's Avatar
i boogie for the raindrops
you should really pick a sub before you pick an amp. the sub is what makes the sound and what sound like it should sound like, the amp just makes it move.
Old Aug 1, 2003
MangoEX's Avatar
Just Be
...You're right. ill look into it.
Old Aug 1, 2003
Mystic3030's Avatar
Buying online? For $150 you have lots of options...JLW3v2, Shiva, Alpine TypeR, Kicker L7, ID or IDQ, Eclipse Aluminums, or Diamond M6 just to name a few........
And I would use 12 guage wire. Hell, I even have 12 guage running to my speakers in the doors.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
