Sponsored by:
Sponsored by: CARiD
Ground Wires?
Old Jan 2, 2003
  #31
Chyna's Avatar
Chyna is an unknown quantity at this point
I bought the hyper ground wiring kit for my ITR but the connections are the same. There are five cables to hook up to make a daisy chain. My kit came with an adapter IOT hook up two wires from the battery.
Disconnect the negative terminal from your battery. From the battery, (1) hook up a ground to the chassis. (2) Also from the battery, attach a wire to your intake manifold. (3) From the manifold, hook a wire to your engine block. (4) Attach a second wire to the intake manifold to the other side of your chassis (opposite side from where you began) (5) From the engine block, attach a wire to your tranny.
After completing the chain, reconnect the negative terminal. Start your engine and idle for 5min w/o the A/C and radio. Then after 5 min, turn on your radio and a/c to insure nothing is blown. If you are still unsure of where to connect all of the wires, look hard at all of the adds to get a better idea. The basis concept is to form a daisy chain.
Old Jan 2, 2003
  #32
YS's Avatar
YS
YS is an unknown quantity at this point
Quote
[hr]Originally posted by: Chyna
After completing the chain, reconnect the negative terminal. Start your engine and idle for 5min w/o the A/C and radio. Then after 5 min, turn on your radio and a/c to insure nothing is blown. If you are still unsure of where to connect all of the wires, look hard at all of the adds to get a better idea. The basis concept is to form a daisy chain.[hr]
can you hook up from battery to chassis, battery to intake manifold, battery to engine block, battery to tranny, and battery to the other side of the chassis ...... where is "The other side of the chassis" located????
Thanks .......
Old Jan 3, 2003
  #33
Chyna's Avatar
In theory it should work. Can't be sure until you dyno it, but the principle is still the same. Do you really want all of those cables coming off of your battery? It may be a little difficult to hook them all up there and then attach to where they need to go. Might look too cluttered. About the "other side", ground the wires on both sides of the car's engine compartment (right side w/ battery on it and the other side where your washer fluid and stuff are).
Old Jan 3, 2003
  #34
YS's Avatar
YS
Thanks Chyna ......... [IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
