Sponsored by:
Sponsored by: CARiD
side marker questions
Old Aug 29, 2003
  #31
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
the sidemarkers i got was from a local shop.. only cost me like 9 bucks.. and its oval amber style with the black rubber around it. compliments my blacked out headlights lights very well..
As for that pic, LJ sent me those 2 pics, and i just chopped them together.
Old Sep 2, 2003
  #32
TeLLy's Avatar
Yes, it's an Acura EL
Originally posted by cosmo
What size of a bulb is in those markers from tornactive? To those who have done the DIY, did you use the nibblers or how'd you make your holes?
The bulbs are 194 (presently burnt out, the new LED ones are in the mail as we speak). My friend installed them at his shop, using a dremel. Actually, he first used a huge power drill to drill a couple of HUGE holes in the fender. Then he did the fine work with his dremel, which broke on him while he was workin on the fender. It's bad enough hearing a drill go into your car's body, but hearing "KACHUNK...Fiiizzzz"...I nearly died. He then bought a new dremel and finished the job. I then bought the dremel off him. Heh heh.
BTW if you are getting sidemarkers installed, do NOT sit there and watch. You will cry as the drill goes into the body panel. Go grab a burger, watch some ****, SOMETHING.
Old Sep 2, 2003
  #33
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Drilled a few holes to make enough room for the nibbler to get in then went to work with the nibbler. Its real easy to use and can make a surprisingly clean cut if you use it right.
-Kre
Poopies
Apr 20, 2017 11:36 PM
h4ldol
Jun 3, 2015 03:26 PM
CIVICINJEN
Nov 16, 2001 11:44 AM
CIVICINJEN
Nov 16, 2001 09:42 AM
CIVICINJEN
Nov 6, 2001 01:30 PM
