Civic 2006 another ac issues
Old Jul 26, 2018
contevo's Avatar
contevo is an unknown quantity at this point
Hello, I know is another ac issue I read few post but did not help me with my issue. So recently my ac condenser fan went out and I ordered another one and replace it. I was hoping that was the problem but no my ac don't cool while idling but cools while driving but hot days doesn't cool much even awhile driving but at night my ac cool nicely awhile driving and idling but not much but I feel the air gets cool than warm on and off.
here is a video I made ac on max and gauges plug in the low pressure and compressor is running and fans are on what is going on??
Old Jul 26, 2018
Re: Civic 2006 another ac issues
Well that video didn't show me anything helpful other than the low is running 45PSI and that seems high. What's your ambient temperature at the time of the check?
You have a gauge on the low side......but what is the high side doing?
Does the compressor ever cycle? At idle? While driving?
Has someone added freon? Correct freon used? Recover-evacuate-recharge BY WEIGHT?
Does the new fan spin the correct direction? (both fans have to pull air from front to rear)
Old Jul 26, 2018
contevo's Avatar
hello thank you for ur reply. The fan blowing air toward the engine away from the condenser. And I see compressor spinning I was trying show it in the video but I did it too quick and looks like the compressor always going even on max and normal ac I'm in Texas so was about 97degree and my friend is checking my high after work he has the professional gauge thing. I had the compressor replace year a ago and idk what they did I wasn't around for it all I cared was ac work and the job was done for free by dealership I got the car from.
Old Jul 26, 2018
If he really knows what he is doing then he should be able to tell you exactly what's wrong once he connects the gauge set and gets some readings and evaluates the system.
deanh22a
Aug 18, 2017 07:55 PM
Packrat0113
Jul 23, 2017 09:36 PM
jonprince
Jun 19, 2010 02:05 AM
DaMadScientist
Jan 17, 2007 05:48 PM
EM2Civic
Jun 13, 2004 07:59 PM
