Phantom DRL's
Old Mar 22, 2014
jstngrms's Avatar
jstngrms is an unknown quantity at this point
Phantom DRL's
So, apparently i have a magical 2007 civic. I was sitting in the house watching TV and when i looked out my window the daytime running lights (two orange ones in front, tail lights, and license plate light) were all on. My car hasn't been started in 3 days. I don't know when they came on but they wouldn't go off no matter what i did (started it, flashed the lights, etc). I ended up just unhooking the battery and hooking it back up and they didn't come back on. This worked for a week, then it happened again. Any ideas why my DRL's just magically come on while my car is sitting in the driveway? Very frustrated.
Old Mar 23, 2014
Re: Phantom DRL's
Headlights not on?
That sounds like the park lights.
Got anything aftermarket in the car? Remote start, alarm? That would be the FIRST place to start.
I can't think of any reason something stock would turn the lights on and leave them on for no reason.
I might guess either the switch contacts stuck on, or relay contacts stuck on.....but usually when one of those happens the lights would be stuck on ever since you last turned them on.
Got water leaks or damage in the interior?
This might sound stupid....... Next time it happens, smack the dash fusebox and see if the lights turn off.
Old Mar 23, 2014
jstngrms's Avatar
Re: Phantom DRL's
Park lights yeah i guess not DRL's. I do have after market remote start. Which actually hasn't been working right for a while, i never even thought of that, thanks ill look into it.
No water leaks or damage that i know of.
At least you've given me a place to start i've been racking my brain on this, so thanks.
Old Mar 23, 2014
Re: Phantom DRL's
Remote start that's already got a problem? Yeah, that just went to the top of the list of possible suspects.
I bet the exact same lights are on when the remote start is used.
You could go in and unplug/disconnect/remove the remote start, or wait until the lights are stuck on again and unplug/disconnect/remove the remote start at that time.
If you wait until it's actually happening (lights stuck on) you could at least find out for sure if that IS the culprit, but, you could be risking a long wait or you could risk killing the battery if you don't catch it in time.
HTH
mac25
Aug 21, 2015 11:14 PM
eorlando1
May 17, 2015 11:16 AM
phuviano
Lighting
Apr 16, 2005 05:24 PM
FurBall
Aug 29, 2002 02:57 AM
